Question about RTO Letro Jet Vac Automatic Pool Cleaner without Booster Pump
My jet vac will just sit in corners and stay there for days/weeks until I move it. Then once it hits a corner, it is stuck again.
WHEN MY WASHER SPINS THE BOWL HITS THE SIDE OF WASHER MACHINE SO HOW DO I STOP IT FROM HITTING THE SIDES
Start off by following my guidance notes on balance/leveling-
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 12, 2011 | Washing Machines
Washer sounds like a jet engine about to take off while spinning
Check the machine balance first :-
John C
Jul 24, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I kept getting an error message UE - I "fluffed" the load, even removed some items. Unplugged the machine, cleaned out the filter, used a Shop Vac to remove excess water and also tried to clear...
Sorry, I don't know your particular machine but UE could mean Unbalance Error. Does the machine vibrate/move particularly when spinning? If so this could be the reason so here are my standard guidance notes to cure ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly!!!
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Feb 22, 2011 | Washing Machines
I'm trying to set my son's Timex 1440 watch. I can get the minutes blinking but when I touch the top right button it only moves the minutes in 30-minute increments. So i can set it at 8:30 or 9:00, for...
I had the same problem with the watch my wife bought me. On the mode make sure it doesn;t say T2 in the top right hand corner. if it does you are in the wrong mode. Hit the mode button until it shows the day of the week highlighted and a date and then go through the normal time set procedures. That worked for me.
Dec 25, 2010 | Timex 1440 Nylon watch
Stuck in corner
Try adjusting your returns to change the currents in the pool and see if that helps.
Oct 13, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
May 26, 2009 | Pentair Jet - Vac Pressure Side Inground...
1996 Camry 100 km stalling
You have one of two very common problems.
Number one may be a stuck open EGR valve
Number two would be a failing Idle Air Control valve (IAC).
Try this: Open the hood & locate the EGR valve, close to the firewall, behind the intake. Find & take with you a small hammer. The next time that it happens, open the hood & tap on the EGR valve. If it is sticking "open" the tapping may dislodge the carbon particles that are keeping it open.When the EGR valve is open, exhaust is getting into the intake at idle, and this will def stall out the car.
There is no repair to the IAC valve, it would need to be replaced if it is bad.
One of these two scenarios will cure your problem, I see it every day.
Oct 07, 2008 | 1994 Toyota Camry
2002 chevrolet monte carlo
My car was doing the same thing. It would stall out while idling or even turning a corner. I ended up replacing a few sensors but the problem was the fuel injector pressure regulator. The check engine light never came on. It was leaking fuel through the vacuum side of the diaphragm. Disconnect the vacuum hose from the pressure regulator and if there are any traces of gasoline it needs to be replaced.
Sep 09, 2008 | 2002 Chevrolet Monte Carlo
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 | Watches
RTO Letro Jet Vac Automatic Pool Cleaner without Booster Pump Logo
126 people viewed this question
Top RTO Pool & Spa Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
