Question about D-Link DIR-615 Wireless Router
I need to connect my printer to my wireless router.
  • Eduardo Rodriguez Mar 15, 2011
    what is your printer brand and model?
  • jacobdady Mar 15, 2011
    its a Cannon Pixma MP250...bought it at walmart for 32 bucks.. couldn't pass it up
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
Assuming your printer is network compatible:
  • If it uses Wireless, use your printer's configuration to connect to the D-Link's network. You may also want to use the D-Link's built-in DHCP controls to assign a single IP to your printer for simpler setup
  • If it has an Ethernet port, connect a cable from the Printer's Ethernet port to one of the 4 ports on the back of the router. This should connect the two and all going well, most printers will sort themselves out from here.
If your printer is not network capable, you will have to connect the printer to a computer then use Windows sharing options to share that computer's printer with the network.
Hope this helps, Alistair
Posted on Mar 15, 2011
I cannot work out how to connect my printer with my d-link DIR-655 router. When I take the printer USB out of my computer and plug it in to the USB port on the router, I cannot print from mycomputer. I...
You cannot set the printer up directly on the router as the router needs to have a driver to understand how to use the printer. If you have a wireless printer, you need to enter a wireless key on the printer, you'll have to do that from the printer interface (you didn't list your printer model so i'm not sure how exactly you do that). On my wireless printer there is a nice network setup menu on the touch screen display.
Then you have to install the full drivers for the printer and tell it the printer is connected wirelessly and it looks for it and finds its IP address and allows you to connect to it.
If you do not have a wireless printer, and need to print wirelessly, you will need to buy a print server.
Apr 17, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I have a wireless printer and it won't connect. I tried text sopport for the printer and was told that the router needs to be insinck to the mac address . I would like to know if you could tell me how to...
Setting up wireless printers can be such a hassle!
The quickest solution is to let the router sync the mac address itself, don't worry about the details of it all. Easiest way is to start wired, before you go wireless.
When setting up the printer to work with that wireless router, hook your printer up directly to the router/computer the router is connected to. This will allow for the printer/router to recognize each other and establish a connection. Then, when you use a wireless connection (wireless on laptop/ on printer also), they will recognize each other and you'll be able to connect.
This is much less of a hassle than trying to set up wirelessly.
Best of luck!
Mar 15, 2011 | Belkin (F5D5231-4) Router
I want to connect a wireless Cannon printer to a Toshiba laptop, do I need a certain type of router? I have WiFi and WWAN internet connection, do I still need a router?
The printer needs to be connected to a router.
The router has to be wireless.
The laptop should then be connected to the router in order to install.
The printer shoul have an option to search and connect to a wireless router. After searching an connecting, you have to connect the laptop to the router and install the printer as an network printer.
Sep 21, 2010 | Computers & Internet
Can i hook my printer to this router Linksys wireless-g 2.4ghz
You want to connect a printer to the network.
If you have Ethernet port on the printer then you can connect it to the router with the ethernet cable. IF it is wireless printer then you will need to connect to the wireless network on the printer. In both the cases you will need to set up your printer as a network printer. If you contact the manufacturer of the printer they will tell you how to do it.
If you do not have ethernet port on the printer and it has only USB port and it is not a wireless printer then you will need a print server. You can purchase a wireless print server and you can set it up so that all the computers will be able to print onthe same printer.
If you have only the USB port and you don't want to use print server, then you can connect your printer to one of your computer. Enable File and printer sharing on all the computer. If you go to microsoft.com and search for file and printer sharing, you will get steps to enable file and printer sharing.
If you want to check the wireless settings of the router, you will need to open the set up page of the router .
Click here for more information about router and networks
Mar 21, 2010 | Linksys Wireless-G WRT54G Router
I have changed my wirelss router toa Linksys and now need to set up wirelss printing from my HP6110. how do I do this? The new wireless router is a WRT310N.
You will need to check the wireless settings of the
router
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
IS your printer wireless or it is connected to the computer.
If printer is wireless then you will need to connect to the wireless network.
If it is connected to the computer and you want to share the printer then you will need to enable the file and printer sharing on all the computers.
Click here for step by step instructions
Jan 23, 2010 | HP Computers & Internet
Can I connect my 2wire to my printer to print wireless, if so how?
router
that computer.
on your printer there will be settings of network connection.
you just need to connect to the wireless network on the printer
Click here to know more about routers
Jan 10, 2010 | 2wire HomePortal 100W (1000-400026-000)...
Can't connect my new Brother MFC490CW wireless printer. I do I proceed to activate my printer with this router (SMC2804WBRP-G)
ti is a wireless printer.
You will need to connect to the wireless network on the printer.
you will need to check the wireless settings of the router.
Click Here to know how to check the settings of the router.
Nov 01, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
How do you connect a printer to this?
Basically, if it is a wireless-ready printer, what you need is match the same wireless settings that you have from your router.
On most wireless-ready printer, you need them to connect temporarily to your computer through USB connection then run the Setup CD. You will then have the option to configure the wireless settings (the same that you have on your router), then install the printer driver afterwards. You'll be prompted when to unhook the printer from your computer to make it wireless.
Oct 28, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Hi i have a lexmark all in one printer,recently i changed my router and now cant connect the printer wirelessly to the computer!
You will have to reconfigure the printer with the router and then reconfigure the PC. All routers don't have the IP address range. That might be the reason why it isnt working after changing the router. Also, if you were using the printer wirelessly, the SSID (network name) and the wireless security needs to be reconfigured to match your new router. The simplest way to achieve this would be to connect the printer hard wired to the router; uninstall the printer drivers completely from the PC; and run the setup disk again. The setup will walk you through the whole process.
Please get in touch if you need further clarifications.
regards
Sandeep
Oct 27, 2009 | Office Equipment & Supplies
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
D-Link DIR-615 Wireless Router Logo
174 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
