Question about Dell Inspiron 537s (DDCWRA2_6) PC Desktop
My Dell Inspiron 537s stopped working and won't turn on. There is a green light in the back when I plug it in, but the power button in the front does nothing. I am assuming it is the power supply, but need to figure out how to be sure before I find and install a replacement.
    Scholar:
  • 80 Answers
The only way to determine if the power supply is no good without replacing it is to get a Volt Meter and test the Output on the current Power Supply. If you are getting the correct Output Voltage (correct Output Voltage may vary from computer to computer) then it is not the power supply, but if you are getting a 0V then your power supply might be damaged or blown a fuse, or just simply dead.
You can try to see if you can buy a power supply with a return policy just to see if that fixes the issue.
Please rate if this helps
Posted on Mar 15, 2011
My dell 545S will not boot up it blinks amber for about two minutes then turns solid amber and the funs(all three) run but will not start!!!
If you are not getting any beeps its either the powersupply is back or the motherboard is bad. You can try replace one at a time
Aug 11, 2014 | Dell Inspiron 535s 537s 545s 546s 560s...
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell Inspiron Desktop 546MT, green light on the back, but no light on the front
Could be a faulty switch, switch wire connector loose from the motherboard, faulty power supply.
Jan 29, 2012 | Dell Inspiron 546 MT Desktop Computer
My Dell Inspiron B130 won't turn on. The battery light blinks yellow twice then green, but that is the only thing happening.
Take the battery off completely and drain the flea power from the laptop by holding down the power button while the battery is off. Hold down the power button for about 15-20 seconds to ensure no power remains on the laptop. Check if your battery has a drain button too. Drain the battery and place it back on the laptop.
Charge it for about 30 minutes before you turn it on. See if it works.
Post here if you need further help.
Jul 30, 2011 | Dell Inspiron™ B130 PC Notebook
Will not turn on when power button is Dell Inspiron 518 will not turn on when power button is pressed. Green LED on back of powersupply lights and orange LED on motherboard turns on. No fan operation on...
Green LED on back of power supply indicates it's getting power. That does not mean that it's distributing the power voltages to the computer. You could have a bad power supply or a bad motherboard. Just to make surethat nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 13, 2011 | Dell Inspiron 518 Desktop Computer
My Dell Inspiron B130 will not turn on
The battery is critically low, indicating that it is not getting a charge from the AC adapter. If the system will not power on from the AC adapter, then the motherboard power connection is suspect.
Motherboards are about $100 on EBay
Feb 01, 2010 | Dell Inspiron B130 Notebook
Dell Inspiron 537s (DDCWRA2_6) PC Desktop Logo
717 people viewed this question
Alun Cox
