Question about GE WWSE5240G
I have a ge wwse5240g2ww. When I choose the load to "super" it overfills. When I choose "large" it fills all the way to the top of the tub. It acts like this over exageration on all load sizes. Small to medium, medium to large, large to super, and super just overfilling the tub as stated before. I'm not exactlly sure whether it is the cold or hot as we wash all loads with hot water and both the hot and cold fill the tub and rinse of course with cold. Could this problem be the fill valve sticking or is there some kind of sensor or level limit switch??? Please help as I have to keep vacuuming up the over abundance of water. Thanks, Shop Vac Wayne
  • 641 Answers
SOURCE: washer overfilling
There are two reasons could cause washer's overfilling. - A defective water entrance valve - Water supply to the dishwasher is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. - Water switch level - I am not familiar with this specific machine, but there are 2 types of level switches. 1)A diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. 2)Floating switch that located inside the dishwasher's bottom and operate a switch. In case there is a floating switch in your dishwasher - check for its smooth movment and check as well the switch by a multi-meter (an on/off switch). Defective switch should be replaced. If level switch in your dishwasher is a diaphragm device - Open the rear panel, find the device and clear first any obstruction in the tube.In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it will not react, you should replace it. Good luck !!
Posted on Jul 02, 2006
  • 1294 Answers
SOURCE: GE washing machine overflows water fill will not shut off
You just have to replace the inlet valve, can do it yourself.
Posted on Jun 13, 2008
eagle338
  • 4889 Answers
SOURCE: the washer overflows with water. help
Overflow is usually caused by a “stuck-open” fill valve, and the cold water half of the valve is usually the culprit.
This can also be caused by the fill system control components: pressure switch, pressure tube, or pressure tube dome/port. So let’s take a look at these.
First of all, determine whether your overflow condition is mechanical or electrical. Start the washer filling, then turn the timer off by pushing the knob in. If the fill continues, pull the washer plug. If filling continues with the washer unplugged, you have a mechanical problem - nearly always a stuck valve ***’y. Replace the fill valve.
If however, the fill stops when you unplug the machine, you are looking at an electrical fill control problem, and it gets a little more complicated.
Here a small piece of rubber or plastic tubing is handy. Unplug the washer and open the console where you’ll see the pressure switch. This is the switch with a small rubber tube, usually clear, sometimes black, attached. Pull this tube off and replace it with your short tubing. Blow a bit of pressure into the switch using your mouth, and listen for a click, then another when you release the pressure. Hear two clicks? Good! The switch is probably OK, but we’re having fun, so let’s continue!
Plug the washer back in (being aware that components in the console are now hot)and start the washer filling again. With it filling, again blow a bit of pressure into the switch. If the switch is good, the fill should stop and the machine should start to agitate.
This verifies that the pressure switch is working, and causes us to suspect the pressure tubing or a clogged port/dome to which it connects. Wipe off the end of the original tube you removed from the switch, and blow into it. You’re blowing air down into the tank now, and you should feel very little restriction. If it is very hard or impossible to blow through this tube, the tank dome or port is clogged.
Older Maytags are known for this, and if you have one, spin out all water, remove the ‘Corbin’ clamp from the pressure tube outside of the tank and pull the tube off. (Pull washer front off – 2 Phillips screws at bottom, then two 3/8 in. hex screws release top, which swings upward) You will probably see ‘gunk’ clogging both the rubber tubing and the ‘spud’ that is a part of the tank. The hose ***'y can be taken to a sink and flushed clean with hot water, and an old toothbrush used to clear the tank spud, which, in the Maytags, is about 3/4 in. ID.
It is best cleaned from the inside, which means pulling the cabinet and tub. Not beyond the reach of the handyman, this job does require a special spanner wrench to remove the tub nut, as well as the removal of some other components. I’d probably recommend this one as a job for the pro. An experienced tech will have seen this before and be in and out in an hour or less.
The tank port on these washers is too small - only about 3/8 in. diameter, and hard to clean, even from the inside. Here’s yet another job for the trusty wetvac. We are hopeful that Whirlpool will soon enlarge or baffle these ports to correct this problem - one of very few ‘glitches’ these excellent machines have.
Whatever your brand, if air can’t be blown back through this tube, the port or dome will need cleaning.
If you have no trouble blowing pressure through it remove the tube completely and inspect it carefully. This tube must not have the smallest hole in it, and we sometimes see them worn through or, more often, chewed through by mice. I mention this last because, while it is the least common cause of overflow I see, it does happen and is easily overlooked. We run into this a couple of times each year, usually in the Fall when the mice are looking for a warm winter home.
Also uncommon, sometimes this tube will swell and loosen a bit, leaking air where it attaches to the tank fitting. If you suspect this, or the tube fits very loosely, simply cut 3/4” or so off the end and push it back on.
One last comment on this concerns some newer Frigidaire 27” (wide) machines. These use a piece of tape (!) to secure the pressure tube to the outside of the tank. This tape has to be there (don’t ask me how I know!) or the tube will pull off while spinning, causing flooding. If it has come off, or was removed for service, be sure to replace it. Duct tape will work well; just be sure to clean the tank before attaching to be sure it stays put. Naptha (lighter fluid) will do this well.
Hope this helps,
Sai.
Posted on Sep 11, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Posted on Feb 21, 2009
Washer overfills & excess comes out from underneath
what is your model number then we can get started then okay
Feb 11, 2013 | GE WBSR3140DW Top Load Washer
GE Top load Washer Model wwse5240g2ww fills with water and then does nothing else
This may require a technician visit, but you can check this:
Open front panel by using a putty knife to push in and release a clip at the seam where the front panel meets the washer's top. (usually about 2 inches in from each side.) Look at ( BUT DON'T TOUCH !!!!!) the motor. Just under the top plate on the motor is an electronic board which has an LED mounted on it. Anytime the washer is plugged in, the LED should be slowly flashing, about once a second. When the motor is running, it should flash twice as fast. If you get anything else, like four flashes, a pause, and four more flashes, call for service and let them know the flash code you are seeing.
Nov 18, 2011 | GE Washing Machines
Purchased a GE washer WHRE5550kww need to know why it isn't filling to the top 'holes' when set on large/super wash?
Hello....I don't know the answer to your question, but would like to know if you like this machine in general, are you happy you bought it??? Would you buy it again? Thanks
Aug 04, 2009 | General Electric WHRE5550H Top Load Washer
GE wbsr1060T washer overflows on 'Super' load size setting
HI, there is a pressure switch for the water level regulation that seems to be malfunctioning in your unit at this time. You will need to replace this switch asap. this will correct this issue.
Click here to order
Jul 26, 2009 | GE WVSR1060A Top Load Washer
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
Water fill control
it overflows from the tub then:
This can either be a fault in the fill sense tube( small tube connected to the bottom on the outer tub from the sensor at or near the top of the washer housing ) becoming blocked or broken or a fault with the sensor itself. There is a mechanical adjustment for the level but it is a little fiddly to get the adjustment just right.
If it overfills from the drain hose:
then either the drain hose is too low and the water siphons out before it reaches the maximum or there is a tight seal at the drain hose to house drain port which will cause all the water to siphon out, this can also be caused by a drain hose being pushed too far down the house drain port.
Jul 28, 2008 | GE WDSR2080D Top Load Washer
GE WWSE5240G Logo
67 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
