Question about HTC Cell Phones
Why does my device keep powering off when its fully charged?
  • 341 Answers
Please make sure the battery is good and holds charge. Please try it powering ON while connecting the charger .
Posted on Mar 15, 2011
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Tip
Sony ebook Reader is Frozen, Not charging
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest thatyou perform each step and check the operation.
  1. Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to displaythe charging symbol if the Reader is fully drained in its last use.
  2. Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
  3. Perform a softreset. We can perform a soft reset by pressing the reset button on the Reader.
  4. After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light nextto the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
  5. If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptorand then press the reset button.
  6. Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Readerdevice. Check if the Indicator light next to the powerswitch on the Reader device is yellow (indicating it is turning on) and if the unit is responding.
    If the unit isstill frozen, connect it again to the computer or AC adapter and while connected,check if the Indicator light next to the power switch on the Reader device is red. If this light is red , allow the Reader device tocharge for one hour sothere is sufficient charge for troubleshooting.
    If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
    Under certain circumstances, moisture condensation can occur. Moisture condensation can becaused by moving the Reader device between temperature extremes or if theReader device has come in direct contact with moisture. If you suspect moistureas the cause, allow the Reader device to sit for a few hours before attempting to turn it back on.
Reader is frozen, PRS650 frozen, image stayed in PRS650, Help to reset PRS 650. RESET PRS650. how to reset PRS-650. Hard reset PRS650. How to perform a hard reset for PRS 650. PRS650 freeze, PRS-650 frozen.PRS-650 is not charging, does not turn on PRS 650, PRS650 is not turning ON. PRS-650 does not charge.
on Jan 12, 2011 | Audio Players & Recorders
Tip
Batteries & USB Devices & Charging
I see lots of people have trouble with their batteries for their various USB connected devices. Unfortunately you cannot usually charge a totally flat battery, or even a 1/2 charged one... from the USB port. These are only used to "Top Up" the battery... & keep it charged up via a "Trickle Charge". at very low current.If your battery is in this condition then you need to replace it with a fully charged one, and then use the USB to keep it fully charged.Another way is to connect the "Flat" battery up to a power supply or machine that charges them, at the right Voltage (Usually 3 - 6 V) & Current rating, and once fully charged, then use the USB.
on Jan 29, 2010 | Computers & Internet
The battery does not charge anymore
Usually, the battery life can (quickly) decrease if your GPS is always plugged into a power source (even when not in use).
Like all such (lithium) batteries, to keep the battery healthy, it's better to charge it fully, then use / deplete it fully (while not plugged into a power source) and repeat the charge cycle.
If your battery doesn't charge anymore, you'll just have to use the GPS while it is plugged in. If that is even not possible (because the device actually use the battery to power it, and not the direct current from the charger), you may want to consider replacing the battery. Or, replace your GPS.
Aug 28, 2013 | Tomtom One XL GPS Receiver
Very short battery life
Often this is the result of keeping the device plugged into a power source all (or most) of the time, even when it is not in use. The battery literally looses it capability to hold a good (long) charge.
So, you'll need to keep the device plugged in (to a power source) every time you need to use it ... to continue using it. Or, you may wish to replace the battery. And if / when you do, just remember to charge it fully, then unplug it and use the device (to run only on the battery) until the battery is depleted before plugging it in to charge it (to full) again. This way, the battery will last longer.
Aug 08, 2013 | Tomtom GO 920 GPS Receiver
Htc one s keeps powering up and down
Make sure your battery is fully charged.
You may also want to charge it fully while the device is powered completely off, after turning it back on check
Settings -> About phone -> software update
to see if there is an update for your phone and also make sure it does this using a Wireless connection
Oct 06, 2012 | Cell Phones
The led keeps on blinking and don,t load the battery
Hello there,
If the led light on your gps heeps blinking, then it simply means there is not enough power to start it up for you. Please ensure the battery is fully charged before you try to power it on. Also be sure that the battery is holding a charge by trying it out on another device and charging it there. Ensure also that your charger is also working.
Hope this helps. Goodluck Elect_Comp
Sep 02, 2011 | SNK CarTrek 400 Car GPS Receiver
My sony ereader prs-650 is stuck on sleep mode and it wont do anything ,, it wont charge when connected to the computer
Each step in my solution is a possible resolution. Hence I suggest that you perform each step and check the operation.
Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to display the charging symbol if the Reader is fully drained in its last use.
Perform a soft reset. We can perform a soft reset by pressing the reset button on the Reader.
After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light next to the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptor and then press the reset button.
Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Reader device. Check if the Indicator light next to the power switch on the Reader device is yellow (indicating it is turning on) and if the unit is responding
If the unit is still frozen, connect it again to the computer or AC adapter and while connected, check if the Indicator light next to the power switch on the Reader device is red . If this light is red , allow the Reader device to charge for one hour so there is sufficient charge for troubleshooting.
Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader device between temperature extremes or if the Reader device has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader device to sit for a few hours before attempting to turn it back on
Jan 12, 2011 | Sony Reader Touch PRS-600
I have ER224 RC hair trimmer, I have been charging this for 2 days, it's led is still RED, i dont know if it is fully charged yet or not? is the led green for fully?
some devices doesn't have indicator that it is already fully charged so my advise is since almost all rechargeable gadgets needs to be charged 4-8 hours depending on the power needed by the device for example a cellphone that uses 37 volts li-ion battery should be charged 3-4 hours to use it in its maximum capacity. so look how much power needed by the device and charge it at least 4 hours for the battery to be full.
Dec 17, 2010 | Panasonic ER224
Can i charge the camera other than through the usb cable ??
Hi!
USB charging is not possible. You need to have the battery charger to be able to fully charge the battery. This should come along with the camera kit.
USB charging is possible if you will buy this: http://fujifilm.co.uk/consumer/digital/digital-accessories/usb-chargers-travel-adaptors-153171/world-adaptor-plus-usb-charger
"For charging by USB, simply change the head and plug in your iPod, mobile phone, PDA or any other 5V USB powered device to keep it fully charged wherever you are."
Aug 25, 2009 | Fuji Finepix Z20fd Digital Camera
Cell Phones Logo
108 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
