Question about HP Computers & Internet
How to change printer ink cartridge - HP Computers & Internet
    Scholar:
  • 65 Answers
This is fairly simple. first make sure you have the proper replacement cartradge. then open the frount of your printer. your cartridge compartment should slide to the middle. to open these compartment you should look at them they should have an arrow or some sort of instructions. remove the old cartridges, take the new cartridges and make sure the securtity tape has been removed from over the bottom. then place them in the proper slots, black/color. firmly push them in, and close the ink compartments and the frount of your printer. you should be ready to go! if these instructions were not helpful, you should refer to the printers user manual and lookup ink replacement. if you have no manual, then search for your printer type and model and check out the faqs.
I hope this information was helpful.
Posted on Aug 01, 2008
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Printer doesn't revognize new ink cartridge
Are you using Dell Series 5 ink cartridges? Dell Series 5 ink cartridges have a cartridge that cannot be reset.
Article on refilling Dell ink cartridges
It's possible to get a bad Dell Series 5 ink cartridge. Return to place of purchase for a replacement.
Rick
May 24, 2010 | Dell 924 All-in-One InkJet Printer
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Changing the black cartridge also require change of color
The printer is very good.I ve been using it for approx 1 year now.The printer works on a combination of both black as well as colour ink cartridges.If any of the cartridge is empty,printer will not print.Kindly call Kodak with your problems at 1800 421 6699 and they will take care of the issue for you.
Oct 04, 2009 | Kodak ESP 5 Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
I changed ink my printer showing wrong cartridge
Make sure you are using factory new Canon ink cartridges.
If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
Don
Jun 14, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
Press down on the ink cartridge lever to raise the ink cartridge lid.
Remove the old ink cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Change printer ink
Turn on the printer.
lower th epirnter's output tray, pull out the extension, and open the cover.
press and release the ink button.
if your ink lights is on or flashing, the printer head moves to the left, and the cartridge that need to be replaced stops under the ink out mark.
open the cartridge cover
Pinch the back tab of the empty cartridge as your left it out of the printer.
shake the ink cartridge 4 to 5 times while it is still in the package.
unwarp the new ink cartridge and lower it into the holder. Push down gently until the cartridge is firmly seated.
repeal the procedure if more than one ink cartridge is out.
close the cartridge cover.
close the printer cover and press the ink button.
The green power light flashes and the printer makes noise. charge takes about a minutes. When it's finished, the green power light stops flashing and stay on, and the red ink light should go out.
Oct 10, 2008 | Epson Stylus C66 Photo InkJet Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Computers & Internet Logo
69 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
