Question about Dishwashers
Hi silverdragon, re the dishlex 302 not heating or drying Have replaced heating element but unfortunately still cold. If the control panel has not shorted which it hadn't before, do you have any suggestions. My hubby would rather wait before buying a new dishwasher, but I don't want to throw good money after bad. Is there anyone you can suggest who would be able to check out the circuit board to see if i have missed anything.
  • Marion Haywood
    Marion Haywood Mar 15, 2011
    Hi again,
    Where is the temperature thermostat located. Would it be obvious if it has blown out.
    Marion
  • 4,323 Answers
Hi
Check the two thermostats located at the inside bottom front panel of the dishwasher, if any one of them goes bad it won't heat. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 15, 2011
  • 12,061 Answers
Hi, have a look at the thermostat temperature sensor too... the elements while they do burn out, it isn't too common for it to spontaneously fail, however the temp sensor, or "Other" sensor can cause symptoms as you describe... that's the whole problem right there see, so many faults have same or similar symptoms one really needs to examine the machine to tell.
The main board also is a major culprit, often power disturbances, outages, storms etc, can cause damage to the machine's electronics.
a piece of advice, it nearly always pays to call a professional, contact your manufacturers local or head office and ask for a referral to their authorised service centers, then request a serviceman call, to give you a "Quote" as to the repair, now when they call, simply ask for a "Quote" for the repair, if it seems acceptable, offset against a new unit verses the age of yours now, and you can then make an informed decision, that shouldn't cost you much to find out, or go on to a "Fix". Or look towards obtaining a replacement.
It may indeed be something simple?
DISHLEX DX302 REPLACE HEATING ELEMENT
Remove the device and then restart again
Jan 25, 2014 | Dishwashers
I have a dx302. its not heating the water or drying.
download this manual...
http://epubl.luth.se/1402-1617/2006/118/LTU-EX-06118-SE.pdf
Aug 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dx302 not drying dishes. Doesn't seem to be as hot as usual when opened immediately after finished. Steam not present.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Mar 04, 2011 | Dishwashers
No drying cycle on the electrolux dishlex 302 any idea's
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Nov 10, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Elextrolux dishlex DX 302 - not cleaning dishes properly and dishes still wet after drying
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 12, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
The dishlex 302SB is not producing hot water for the washing
I have a Dishlex 302 which had this fault. Initially I thought it was the inline heater element and replaced it. It seemed to work but later no hot water again. Someone here put me on to the problem. There is a dry joint in the control board in the top of the door. This controls the relay which powers up the heater. Unplug it from the mains (very important) and undo the screws around the top of the door (don't take the door right off!) you will be able to wiggle off the front panel containing the electronics. The control board is ealiy disconnected an removed from the machine in its protective plastic cover. Have a look around the PCB and you will see the dry joint. Resolder with rosin core (electronic) solder, reassemble and you should have hot water.
May 23, 2009 | Electrolux 504199 Dishwasher
Dishwasher Dishlex DX302WB No Hot Water
Thank you This worked for me!
The heater was ok found dry joint on pc board
see attatched photo
Took top 6 screws out of door holding front panel in place
Removed front switch panel
I then labeled the 6 cables with 6 being for the heater
Removed pc board from housing to find dry joint
using small piece of wire and solder repaired board
re assembled
now as good as new
May 08, 2008 | Electrolux 18 in. ESL4114 Slim-Line...
Dishlex dx 302 heat drying
Found I had no hot water in my Dishlex DX302 and did a google search and found this page.
My problem was found to be the same as the others; one of the solder joints on the relay on the control board had arced off.
You could see the burn mark on the board and cover where it had been arcing.
Soldered it back together, and now it seems to be going good again.
Now my only problem is a damaged door seal, which means a small water leak; I have used part of a rubber glove to bridge the gap, and it reduces the water leak.
Sep 22, 2007 | Dishwashers
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
