Question about Vizio GV42L 42 in. LCD Television
LCD tv Vizio 42 inch has vertical colored lines completely across (vertically) the entire screen. Here's the picture: [IMG]http://i22.photobucket.com/albums/b320/Relicario/lcdtvverticallines.jpg[/IMG] <a rel='nofollow' href="http://s22.photobucket.com/albums/b320/Relicario/?action=view&current=lcdtvverticallines.jpg" target="_blank"><img src="http://i22.photobucket.com/albums/b320/Relicario/lcdtvverticallines.jpg" border="0" alt="Photobucket"></a>
  • jmvega7 Mar 15, 2011
    So the lcd panel is not damaged? I don't mind spending to repair other boards, but i want to make sure it's not a bad lcd panel (unrepairable). Thank you very much for the quick response. I greatly appreciate it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Vizio Expert
  • 177 Answers
Hello imvega7, as i know, 42 inch is a plasma display TV.
Refer to your image, and my experience that symptomp because of connection between buffer PCB and panel. Some cases, dirty conection may cause this symptomp.
Un plug power cord, open rear cover, fine pcb on upper or lower panel.
unplug flat cables from pcb buffer, clean soket using a brush. And also clean flat cables using celaner or alcohol.
Wait untill that conection dry. reassembly and try it.
i hope that help you.
Posted on Mar 15, 2011
Testimonial: "Very detailed."
    President:
  • Vizio Master
  • 749 Answers
9 out of 10 times this would be a bad LCD , which can't be repaired at a reasonable cost.
Maybe 99 out of 100 is more accurate.
The T-CON having gone bad is your only choice, but the T-CON for this Vizio model does not usually fail in that way.
Which doesn't say it can't do it, it only makes it even less likely.
Selling it on Craigslist to the highest bidder may be the best walk-out option for you.
Amazingly many people buy TVs in hope they can fix them cheap.
Of course they buy them cheap too...but better that than having to spend time and money on trying to fix something that likely can't be fixed.
Hope this helps!
www.coppelltvrepair.com
Posted on May 23, 2014
  • 11,361 Answers
This is LCD TV, not Plasma TV. Try reseating the ribbon cables between the LCD panel and the T-CON board to see if it helps. Main board driving the T-CON board can be bad also, you will need Oscilloscope to look at the signals to verify for sure.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Mar 31, 2011
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
My Vizio E470i-AO has a light gray horizontal streak about 6-inches wide that runs across the entire screen with a tapered vertical tail about. We can watch TV, but the picture is not as sharp.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 24, 2015 | Vizio Televison & Video
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
May 12, 2011 | Vizio L32 32 in. LCD HDTV
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical Line started on left side of HDTV, and now
This problem is down to the actual LCD or plasma screen, if this shows as the screen warms up and stays on then the screen will need to be replaced, you should go back to your retailer (not manufacturer) and report this problem, depending on the store and how long you have had the tv, the tv can be replaced for a like for like tv at store as this is not a cheap standard repair.
Sep 13, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
May 18, 2008 | Televison & Video
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Vizio GV42L 42 in. LCD Television Logo
1,548 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
