Question about Acer AL707 17" LCD Monitor
Where can i get a acer al707 LCD monitor adaptor?
    Scholar:
  • 82 Answers
I believe Acer discontinued that product, however, you can get a similar Acer product (probably of higher quality) for under $100 at this link : http://www.newegg.com/Product/Product.aspx?Item=N82E16824009230&cm_re=Acer_17%22_monitor-_-24-009-230-_-Product
No affiliation with seller. Hope this helps!
Posted on Mar 15, 2011
Acer al707 monitor menu box keeps popping up .Pressing auto config settings stops for a while but then pops up again
There is likely something on the contact that is completing the circuit like someone was pressing the button. Remove the covering and expose the circuit board with the contacts bare and clean with any non corrosive component cleaner. I use rubbing alcohol. Humidity is also an issue if you have the newer touch tech buttons. Gently rub the surface with a dry cloth and remove any moisture, oil or debris from the surface of the buttons.
Make sure to also clean the button backs and anything between the button and contact face on the board. Replace parts and check the fix. If the problem persists it may be an issue with the Main Control Board for your monitor. Component damage or voltage problems will cause similar issues and should be explored by a TV repair technician or warranty to your distributor; as it is likely a failing switch which will have to be soldered off and a new component put on.
Source:
http://www.go-gddq.com/upload/2009_05/09052210427738.pdf
https://www.youtube.com/watch?v=jtwhCBpsx24
Mar 06, 2015 | Acer AL707 17" LCD Monitor
Acer al707 menu box keeps popping up
Make sure there is no button is stuck and if so then there is a card that to be repaired or replaced.
Regards
Mar 05, 2015 | Acer AL707 17" LCD Monitor
Looking for a power supply for acer monitor al1714 can you help
you are looking for an AC power adaptor for your monitor, click on this link : http://www.amiline.com/AC-Adapter-Power-Supply-Acer-AL1714-AL1714b-LCD-Monitor-934271853.html but if you want, you can repair your power AC adaptor.
Dec 06, 2010 | Acer AL1716 F Monitor
Hi I might have downloaded something wrong on my PC, or did something wrong to my flatscreen since every time I shut down for my PC and turn it on again it shows Auto Config in red letters. I didn't do...
Boot up your computer and once it is loaded to your windows desktop, using the image below press and hold the #1 key for about 3 seconds and it will auto adjust the monitor for you. I hope this helps.
Jun 24, 2010 | Acer AL707 17" LCD Monitor
I work from a Acer Ferrari 4000 laptop and use to be connected to a Acer AL707 monitor for a while now but ever since my laptop went in for a new hardrive my monitor gives me a message "Input not...
suzie_q971, You may need to find AL707 driver and download /install it to see if that fixes problem. Software may have been corrupted when new drive was installed on your laptop. Could also be "screen resolution" settings were altered by the technician when doing the laptop repair. If all else fails to work, return unit with monitor and have the tech have a look at it and tell him it worked with the al707 external monitor before. 12fixlouie
May 26, 2010 | Acer AL707 17" LCD Monitor
Is acer lcd 223w compatable with dell dimension 4300?
yes. you will need to know what connection you have on your dell video card. the standard is svga. the other is dvi. you may need a convertor or adaptor.
Dec 27, 2009 | Acer 22" X223w LCD Monitor
Defect in AC adaptor
Traggio,
It's seemd you need a new AC Adapter. You can get a new Universal AC Adapter for your LCD monitor. Check out this website @ www.3rd-rocks.com
Sep 07, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor cannot be turned on
You will need to check the power adaptor for voltage , if that checks out then you will have to check the power circut in the monitor, look at the protection component and diodes in the power circut
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
Acer AL2032W Monitor
Try these #. Sorry I cant assist more!! Good Luck 408.432.6200 1.800.733.2237 or the #s in your user manual.
Jun 20, 2006 | Acer AL2032WD 20" Flat Panel LCD Monitor
Acer AL707 17" LCD Monitor Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
