Question about Sony KP-51HW40 51" Rear Projection Television
HD Outputs The HD outputs on my tv are video 5 and 6. How do I switch it over to the HD outputs?
  • 10,594 Answers
You TV has Component Video Inputs (Video-5 & Video-6) and you can connect DVD Player offering same Component Video Output, with this TV.
Posted on Aug 01, 2008
    Problem Solver:
  • 30 Answers
You mean inputs.
Press the TV/VIDEO button on the remote till the TV goes to the input you want.
2 Suggested Answers
  • 30 Answers
SOURCE: How do I set up the HD on my tv?
Press the TV/Video button on the remote. If it skips those inputs its possible the inputs are skipped in the set up menu you need to go in the menu and set up the inputs...It may be becuase there is no signal to those inputs as well.
Can you connect a hd converter to a Toshiba cx 32 g60 tv
there isn't much point in connecting an hd converter the toshiba cx32g60. the tv can only support an sd signal (composite video or ntsc analog). however, many hd set-top boxes (dvd players, cable and satellite) have composite outputs. these can be connected to your tv. blu-ray videos can't be watched with this tv. (the hdcp (high definition copy protection) can't be sent through most converters.)
if you want to watch ota programming , the cheapest option would be to find an sd digital-to-analog converter. these were the ones sold when most stations switched to digital tuners. some are being sold off as people replace their old analog sets. there are some hd tuner boxes, like this one: http://www.solidsignal.com/pview.asp?mc=03&p=3500stb&d=iview-hd-dvr-receiverconverter-box-for-tv-antenna-qam-%283500stb%29&c=digital%20converter%20boxes&sku= , that have composite video output which will connect to the cx32g60.
i hope this helps.
cindy wells
(if you tried an hdmi to component video converter followed by a component to composite video converter, the signal may degrade excessively.)
Jan 22, 2015 | Toshiba Televison & Video
Yamaha rx-v2500 receiver how to hook up speakers
HI,
Follow these steps to connect a powered sub woofer to your receiver: You typically have two options when connecting a powered sub woofer. Input (1) on the rear of the sub woofer would be used when connecting the sub woofer to the receiver using speaker wires. You would then connect the main speakers to the opposite end, or output or the sub woofer to the main speakers. Option (2) would be using RCA line level output jacks, input (2) on the rear panel of the sub woofer directly to the single sub woofer output on the back of an AV receiver. blank.gif
Oct 06, 2008 | Yamaha RX-V659 Receiver
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
Unable to connect unit to my pc
Your HD tv should have a blue DB15 connector on the back.
If not you need to get a video card with HDMI or S-video outputs.
Is there another issue? If you have the tv cabled to the computer already you need to switch input on the tv to computer via the remote control.
Aug 06, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Turn xbox 360 on and no picture on tv, xbox lights up green but doesnt send video output. tv is hd and i have tryed hooking the xbox up to another tv, tryed using hd and regular video outputs, tryed new...
You may need to change your HD settings on the back of the console ( HD setting is actually on cord ) I had that issue when I first went online w/360 . If that does not help u know X box costumer support will repair any damaged system prob. no cost and does'nt take as long as they say.
May 10, 2010 | Microsoft Xbox 360 Console
I am trying to hook up my home theater system
marvidson,
With the NAD model that you have and its lack of component or HMDI switching, the only way is to connect your system, sort of, backwards.
The only way to do it is to connect your digital cable box and blueray player directly to the tv, then the audio output from the tv to one of the video inputs on the NAD. The NAD has digital coaxial and toslink inputs so if your tv has one of them as an output, that would give you the best sound to the NAD. If your tv does not have either of those outputs, then you will be limited to the composite outputs (red and white) but that will still give you good sound.
Also, depending on the digital output to input configuration, you could possible find a converter online.
-Chris
Jan 19, 2010 | NAD T751 Receiver
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
Aug 01, 2008 | Sony KP-51HW40 51" Rear Projection...
RE: No Outputs working
possible video switching ic or menu settings checked menu first then one at a time start removing inputs to see if one is causing a problem and on which input if all are affected after you checked your meun settings ,possibly internal video switching is at fault.
Sep 08, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
65 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
