Question about Hotpoint Refrigerators
Hi,im having trouble with a hotpoint fridge,model number ctx14cybjrwww.Problem is the fresh food area isnt cold,yet the freezer area is.Thx for any help
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
Freezer working fine, fridge not at all
Brand name and model would help but here is a guess. Most frost free refrigerators have the main cooling unit in the freezer area side. To get the fresh food side cold, there is a small fan in the freezer side that blows cold air to the fresh food side through a duct work or trap door. If that fan stops or fails for and reason, the first place you will notice the temp rise is in the fresh food section. See if you can hear the freezer fan running. You may need to push in the door switch for the freezer light to hear the fan because they sometimes run the fan wiring through the door switch. It may stop when door is opened.
Apr 03, 2015 | Refrigerators
Fresh food side isnt staying cold. Freezer is staying cold though but the ice is sweaty a little. Model RC244AD
Hi I'm Peter, The fresh food side will have a different thermostat it is likely that the thermostat or the thermocoupling has gone bad. The thermocoupling will be a tube shaped device mounted on the coils possibly underneath since it's for the cool side fridge see if it is operating by blowing on it with a hair dryer that may activate it. I would check the thermostat first though. . OH WOW CAN'T BELIEVE I DIDN'T MENTION THIS FIRST Make sure and check the door gasket that it is not leaking a temp gun could be used for that as it would register cooler where there was a leak. Is the compressor running all the time or is it cycling? It seems it would be ok if the freezer is operating properly so it all leads back to the thermostat. Most appliance parts stores will have these in stock just take the make, model, and serial number and they may have some more suggestions as they would most lkely know what parts on a particular make goes out the most.
Apr 17, 2014 | Magic Chef Refrigerators
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
I have frost free hotpoint future,the fridge seems to be working but the freezer isnt at the minute, the food is not freezing and the fan does not seem to be working! it has no suction on doors either, my...
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101.
Oct 15, 2010 | Refrigerators
Freezer not freezing, fridge seems too cold
If the refrigerator is in the house and the temperature in side is between 60 and 80 it should be able to hold good temperatures. If it is in a garage or outside it will not work as well.
If it is inside the first thing to try is resetting the controls. Turn the Fresh food control to a low setting and the freezer setting to maximum. Wait 24 hours and recheck. If this does not work you will need to replace the cold control. To find the part number you will need the complete model number located on the tag.
Apr 18, 2010 | Frigidaire All Refrigerator & Freezer Kit...
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge and freezer is not chilled
power to the house was shut off for repairs, when power was restored the freezer part of the fridge stopped working but the compressor still runs.
Mar 19, 2009 | Hotpoint HSS25GFP Side by Side...
Hotpoint Fridge freezing the food.
If you give me the model number I can find an exploded view, alternatively enter model number here to get the schematics.
Oct 26, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
97 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
