Question about Whirlpool Refrigerators
I have a bottom freezer Whirlpool Gold refrigerator...model#GX5SHTXTS00...S/N#: ECU4029636 purchased 12/2007. The back wall of the freezer keeps icing up and refrigerator does not seem to be as cold. Do you know why this keeps doing this....I'm pretty sure that we keep the vents clear so cold air can circulate but right now the vents in the freezer are all frozen up....how can I fix this problem???
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
The Whirlpool Gold refrigerator is not cooling and the bottom freezer has ice formed on the back of the freezer. I purchased the refrigerator in February 2009.
If you can hear the fan running in the freezer you have a defrost issue. Depending on the Model number it can be a timer, adaptive defrost board, a bi-metal themostat, or heater.
May 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
The meat tray that came with thr refrigerator is made very poorly. is there another meat tray that can be purchased for this refrigerator. our refrigerator has the freezer on the bottom.
Please contact the Whirlpool dealer/distributor in your area for a replacement or upgrade part for your refrigerator.
Thank you for your interest in FixYa.com
Apr 15, 2011 | Whirlpool GB2SHDXTT 22.1 Cu. Ft. Gold...
Have a Whirlpool Gold fridge. Model #GB2SHDXTQ00. This week the fridge stopped working but the bottom freezer works fine. Is this just a thermostatic control issue? What part might be causing the problem? ...
Check the back wall of the freezer for frost . If there is then it is either the defrost heater, timer or thermostat. If there is no frost check to see if the fan in the freezer is running.
Oct 28, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Coil is freezing up
two options...one drain hole blocked in freezer,clean with copper wire/bleach to clear gunge.
two outside temp too cold i.e. unit in garage/outhouse( too cold for compressor )
also check seal to doors.air leaks...
Feb 06, 2010 | Whirlpool GB9SHDXPS Stainless Steel Bottom...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
247 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
