Question about Kodak ESP5250 All-In-One InkJet Printer
Error. Remove rear access cover. Clear all paper. Attach cover. Code 3528. What and where is the rear access cover?
SOURCE: when i try to print with my esp 3250 it says
on the back there is a gray cover on the back right side there is a tab u push in and pull it out but mine is doing the samething and there is no paper in it
Posted on Sep 13, 2010
SOURCE: error code 3528 keeps coming up,telling me to
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Posted on Jan 18, 2011
HansPP
  • 2510 Answers
Check the complete paper path very carefully, it only takes a small fragment of paper stuck somewhere to signal a paper jam. Also check that the paper sensors have returned to their normal positions. See that the printer has not picked up a second sheet of paper and this is somewhere in the path.
Posted on Jan 28, 2011
Joed911
  • 4338 Answers
SOURCE: Kodak esp 3250 printer error.
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
1. Open the printer access door.
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Jan 29, 2011
SOURCE: my kodak esp5210 printer is
I've got exactly the same situation/circumstances and error code, the thing different is that my code changes between 3533 and 3528? sorry I;m no help right now but I'll be back if I solve it. Martin. (Banksy100@hotmail.com)
Posted on Feb 28, 2011
Error code 3528
Look at the back of the printer, you will find 2 latches at the back of the printer, you need to press those latches to open the rear access door. once the rear access door is open you can take the paper that is stuck inside the printer.
Jun 26, 2014 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak 3.2 ESP has an error clear all paper code 3528 but there is nothing there
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Feb 04, 2013 | Kodak ESP 3 Multifunction Printer/ Copier/...
My new kodak printer says the following:Printer error remove rear access cover.Clear all papers Attach cover press ok to continue code 35 28. (The cover will not remove and I cannot see any paper stuck....
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now remove the covers and reset and check the printer properties to see the ink levels.
Activate head cleaning before a test is taken.
Sep 17, 2011 | Office Equipment & Supplies
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My kodak esp5210 printer is showing paper jam remove rear access cover. clear all papper. attach cover. press ok to continue. (code 3533). ive followed the instructions but nothing changes. there never...
Feb 11, 2011 | Office Equipment & Supplies
Kodak esp 3250 printer error. Remove rear access cover. Clear all paper. Attach cover. I removed the paper, and pressed "ok" to continue, reattached the cover, and it still says this. I tried...
Thanks, Joe
Jan 29, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere? and paper is not low????
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
When i try to print with my esp 3250 it says error: paper jam remove rear access cover. clear all paper. attach cover. press OK to continue.. but it doesnt work???
Jun 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP5250 All-In-One InkJet Printer Logo
294 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
