Question about Fulltone Clyde Deluxe Wah Effect Pedal NEW
Fulltone Clyde Deluxe wah distorts and interferes with other pedals, along with a narrow pedal range for the effect, though the pedal has a full sweep. I have gotten no answer from Fulltone on the problem. I have tried different positions in the signal chain, only with an amp, with a battery, plugged into power adapter, and with different cables with no luck.
  • Allen Scarborough Mar 15, 2011
    ok. I tried the Clyde with the OCD before and after. The problem occurs most when the wah is first. It is less of a problem when the OCD is after the wah if I turn down the wah's gain knob on the outside of the pedal all the way down. However, it still "clips" the sound; i.e., compared when the OCD is off, it has a more sudden and less range of effect. Even when the OCD is first, the wah is affected a little. OD pedal level had no discernible effect on the problem.
  • 4,234 Answers
The best way to understand the problem source is to minimize the components. In this case, try the pedal alone first. You need to determine whether or not the pedal is causing the distortion. With the pedal alone, how does the system sound/work? Is it acceptable and performing as expected? If so, then the next step is to add one more effect in the chain. Try the effect BEFORE the Fulltone first. Does the distortion appear? If so, then the problem is likely in the input stage of the Fulltone. It should be able to handle mic level inputs. The effects you are using should be outputing the same level as well. If you are unsure of the output signal levels of the effects, set the guitar to a fixed level and insert one effect at a time. The overall signal level should be similar for each one at the "unity gain" setting.
Please try a few options as suggested above one at a time and report the results here inas much detail as you can. This should help to resolve the problem.
Dan
Posted on Mar 15, 2011
    Thanks, Dan. Like other wahs, Fuzz Faces don't like being after the Clyde Deluxe wah, so when I use them, they are before it (second after a tuner.) It does ok when only Guitar>wah>amp. Used to do ok when OCD and/or TS-9 ODs immediately followed the wah (with or without fuzz before the wah.) I haven't tried the OCD and TS-9 before the wah, but will. I will try to set the gain and "level" settings so everything matches the amp, but will play with that. Also, the Clyde has a gain knob on the side, but changes to its setting has little effect on the problem, just makes the wah a bit louder and sharper. I have a Dunlop Jimi Hendrix wah (the one w/o any boost, etc.) and it works with the ODs after it, but is only a so-so wah, but better than the Clyde with its problems. I will try to get the unity settings right and see if there's any difference. Also-The Clyde has also developed a swoosh sound when you sweep the pedal. Will move some things around to see if there's something causing interference. Have seen some complaints about this on the Net. Only thing I can think of is a Fat Boost on/off pedal from a Blues Jr. amp. Am overall suspecting a malfunction, but will keep at it.
  • ABRsvcs Mar 15, 2011
    I am not familiar with the specific internal circuit of this pedal, but from pedal designs in general, the distortion you are speaking of is more like an overdriven stage than anything else. The difficulty here is that the pedal works as expected when used alone. This suggests a signal level issue between all of the pedals. Without seeing the signals on a scope, it will be difficult to determine the actual source. All I can suggest is to try to insert an attenuator between each pedal stage to bring down the signal levels. This will isolate the problem to hopefully one stage. Then we will need to determine if the first pedal has too high a signal or if the input stage on the Fulltone is overly sensitive.
    Dan
Which is the best wah pedal for my electric guitar?
As per my experience, I can suggest "Dunlop 535Q Cry Baby Multi-Wah".
It delivers a smooth and clean sound.
Its effects and features are very versatile and it's easily workable for gigs or music jams.
It allows selecting the frequency of the effect as well its range.
You can check its review in this link:
Best Wah Pedal Top 7 Best Wah Pedal And How to Find It 2017
Feb 22, 2017 | Electric Music
I need parts for my 2002 clyde deluxe wah.....one knob for the side 3 tone mode and 2 feet with screws....can you help thanks Wayne 443-850-5240.....
You can get the feet at home depot in the hardware section. They should be in the specialty drawers.
you may be able get the knob there also. if not, Radioshack has a small selection of replacement knobs. Do you need the 3-way switch also?
Sep 13, 2011 | Fulltone Clyde Deluxe Wah Pedal Wah-wah...
Hello i bought a Fulltone Clyde Standard Wah and it worked without any problems so far, but lately it started giving some kind of static noise when i turned it on and moved the pedal up and down. I had my...
The pot is generating noise. Some noise is unavoidable from pots. Using excess gain in the amp that that follows it will worsen the problem. If ypu can get to the pot and it has a way to squirt some CRC226 in it would help. You would have to use the spout on the can to squirt into the slot where the leads go into the pot. You can get CRC226 at Home Depot in the electrical dept.
Jul 20, 2011 | Fulltone Clyde Deluxe Wah Effect Pedal NEW
My fulltone deluxe clyde wah is making a noise like cookie monster eating cookies as it goes through it's sweep. any ideas?
Get some CRC226 from Home Depot in the electrical dept and using the spout put some in the pot through the slot IF your unit has a pot with a slot where the leads go in. If the pot does not have a slot, then replace the pot. Also verify the noise is NOT from loose connecting cables by wiggling them manually. The motion of the pedal may be wiggling these.
Jul 14, 2011 | Fulltone Clyde Deluxe Wah Effect Pedal NEW
My Fulltone Wah doesn't "click"
The switch has probably failed mechanically. You will need to replace the switch.
Mar 20, 2011 | Fulltone Clyde Deluxe Wah Effect Pedal NEW
No effect.
Please check if you step full down if the switch under the pedal is switching. If it does than check the battery.
Regards,
Gerard
Jun 02, 2010 | Dunlop 535qc Chrome Crybaby Wah Pedal
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Problem with the sound? Or is it?
I have this exact pedal. The sound should change as soon as you start pressing it down. With a wah, the frequencies are low at the heel down position and steadily change to a treble higher sound when in the toe-down position. Does the LED on the right side of the pedal come on when you press down? Are you using a fresh battery or a power supply with enough current? Is the "loudness" knob effecting the tone when turned up? If the answer to all of these questions is yes...then I would return it for a new one or send it to Morley for repair. They are nice sounding pedals. The problem could ultimately lie in the optical sensor that controls the wah effect.
Jul 29, 2009 | Morley George Lynch Dragon Wah Guitar...
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Fulltone Clyde Deluxe Wah Effect Pedal NEW Logo
212 people viewed this question
Top Fulltone Music Experts
Vito Vacirca Jr.
Are you a Fulltone Music Expert? Answer questions, earn points and help others
