Question about Maytag Neptune MAH5500B Front Load Washer
Have a Maytag Neptune front loader with a balance problem. Tried to troubleshoot and am pretty sure it's the liquid balance ring on tub. Spins unevenly, in washa nd in spin cycle. Have run it without clothes. Checked bearings, struts, spider ring on back of tub - nothing obvious broken. Everything seems fine. Completely dumbfounded as how to fix. HELP! Thanks
    Genius:
  • 1,075 Answers
On the top of the machine is a moulded brick/heavy weight,its split/broken and needs replaced.adrian.
Posted on Mar 15, 2011
Maytag mah55flbwq not draining
Perfectly normal..
What you are actually hearing is a balance ring on the inner tub that has liquid inside to help keep washing loads balanced.
The balance ring is filled with a calcium chloride solution and baffles within the ring allow the fluid to disperse within the ring evenly
By rotating the spin basket you can hear the fluid dispersing within the baffles of the balance ring.
Thebalanceringisfilledwithacelciurnchloridesolutionandbaffles,withintheringallowthefluidtodispersewithinthe:ring,evenly
I also thought ours was not draining properly but discovered otherwise when I had to take the inner tub out for a bearing repair job..
Hope this puts your mind at rest..
Aug 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune fron loading washer and am getting an "nd" error code (indicates draining problem). I drained out as much water as I could by disconnecting the hose and running a wet/dry...
hello, yes the balance ring is liquid filled. The spring is hard for us as techs to get on too. I lock a pair of vise grips onto one end of the spring and pull it downward and pop it on.hope this helps
Jun 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its...
Hello, The earlier Maytag Neptune front loaders have a balance ring on the inner tub that has liquid in it and that causes the sloshing sound when you turn the tub by hand. That is normal.
I noticed that you have a MAH3000... Have you replaced your door latch wax motor yet? If not, it will fail and damage your control board located behind the timer. See NeptuneHelpSong for a video that explains the failure.
I hope this helps...
Apr 25, 2011 | Maytag Neptune Washer
My FAV0800AWW spins then clunks and stops no default code Repairman said $1065.00 to replace inner tub assembly liquid filled balance ring ?
Read through this post and see if you a family member or friend can DIY the issue.
FAV6800A/FAV9800A Outer Tub bearing replacement
Is thhe machine a FAV6800A or FAV9800A?
Feb 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Standing water
do you see water in tub?
if you are just spinning tub and hearing sloshing that is the liquid in balance ring and is normal
Apr 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have a mah4oooaww maytag frontloaded and sounds like the water is not draining removed pump and is clean and drain water still inside drumHow do i get rid of the water in drum
jf you have removed the pump i can assure you the water is out
what you may be hearing is the liquid balance ring on the tumbler front
if it sounds like running water when you turn the tub, it means your balance ring is working'
it is there to keep the machine balanced and is sealed in the ring
Oct 20, 2009 | Maytag Neptune MAH6500A Front Load Washer
Why won't the washer drain? Pump appears to be
if this issue is because you hear water in the machine when the tub spins......
thats normal, its called the balance ring
centrifical force, pushes the water in the lid, outward helping to use the sling weight, as a counter balance
its 100 percent normal to hear sloshing when turning the tub by hand
Oct 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Neptune MAH5500B has a terrible odor and I can hear water swishing when I manually spin the drum.
Pick up some Affresh tablets they are in the detergent isle,and the swishing you here is normal there is a liquid in the balance ring in the front of the tub that makes that noise..
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mah 6500 spins but leaves som water in tub. if you
they have a balance ring on the front of the tub and it's full of water
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
305 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
