Question about Gaggia 74845 Platinum vision coffee maker Coffee Maker
The machine worked fine earlier in the day. There is coffee in the bin, water in the tank. I descaled it yesterday and used the tablets to clean the brewing group. The machine worked fine after doing this. An hour ago I made a cup with the machine and it worked fine. Later I pressed coffee to start making a cup and nothing happened, no machine sounds, i.e. the grinder did not start, other than an error message stating to restart the machine to resolve the problem. I did restart and still got no result
SOURCE: Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Posted on Apr 04, 2009
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 3 Answers
SOURCE: Gaggia Titanium integrated grinder not spinning, not grinding.
your grinding chamber is blocked, the same happened to me, did it struggle to grind before? try taking the black shoot out the top with the 2 screws( were you would put pre ground coffee in) take the brew unit out(along with the waste water and bean tray), and reach up to where there is a little spring, the spring controls a little door, if you open the door manually and clean out the shoot to the grinder( make sure the machine is unplugged for this), i used the end of a tea spoon and a little hoover. it should work after this
Posted on May 16, 2009
  • 36 Answers
SOURCE: coffee takes 10 minutes to fill cup and very noisy - Classic
The most common problem with these machines is scale. Using a good descaler to start with may help but may not always solve the problem. If your machine is noisy it is the pump which may need replacing. If you open the steam valve when making the coffee it will shift any air lock. Out with that you may have to remove the shower plate underneath where the coffee handle goes and give it a good clean. Also there is a safety valve inside the group head which may be clogged up. I am a domestic coffee machine engineer based in glasgow and have machines sent to me from all over the UK. It is hard to eally fix problems without actually seeing the machine as it could really be anything. Boilers are small so tend to fill with scale and ****. go to if you require any more assistance.
Kind Regards
Domestic Coffee Service
Posted on May 28, 2009
SOURCE: no water coming through but steamer working
I have the same problem with Gaggia Baby Dose. there is no water coming through the coffee filter but the steamer is still working. And the shower screen is cleen. Also machine has strange sound.
Posted on Aug 30, 2009
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
Coffee runs too slowly and tastes awful - DeLonghi ECO310BK 15-Bar-Pump Espresso Machine
Yes it may need descaling - deposits like calcium etc from 'clean' town water will build up in the machines boilers and tubes over time - that's why we descale them regularly - even if they don't get a lot of use.
Suggest you get some proper descaling liquid, not vinegar or CLR, read the manual on how to do it (download it off the net if you don't have it). ( it takes a little while as the descaler has to eat away those deposits and the machine will pump a little water out, then wait for a while, pump a little more etc until its finished the process)
Make sure your filter in the coffee dispenser handle is clean as coffee itself will build up and block those tiny holes if the machine is not porperly cleaned each day when used.
Dec 09, 2017 | DeLonghi Coffee Makers & Espresso Machines
My cva 4066 will not make coffee, I descalled it, that function worked fine,all it does is make the grounds a little wet and the rest of the water goes in the drip tray. Can you help me?
Have you Cleaned the Brew unit? The descale Tablets are to clean and descale the internal plumbing - the cleaning tablets are to remove the oils from the brew unit. If clogged the water will not flow through , instead it will dump into the drip tray.
May 11, 2014 | Miele Coffee Makers & Espresso Machines
Descale light came on yesterday, have descaled as per the instructions but the descale light is still on
happened to me once this worked for me . had to fill tank 2 more times to allow the machine to flush the descaling mix (think its part of the cleaning process but the instructions are a little vauge)after this it worked fine
Apr 16, 2011 | Philips Senseo HD-7810 Coffee Maker
The machine says to descale _ How do I do that???!!
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
Jan 17, 2011 | Miele Coffee Makers & Espresso Machines
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
I have two types of descalling tablets in my package, 2 large and 10 small, where do I add them to my Miele coffee system CVA4070, and how many
The large ones are your descaling tablets. they go in your water container when the machine tells you to put them in there. Your small tablets are brew unit cleaning tablets. they go in to the flap door under the ground coffee storage container in the top left of the machine. One cleaning tablet at a time when it tells to to start cleaning. Two descaling tablets at a time during descaling.
Nov 20, 2010 | Miele CVA4070 Coffee Maker
A red light is on and I think its the descaler light...what do I do?
Purchase some citric acid based descaling tablets,
Fill the water tank to the very top and add the tablet to the water
Insert the cleaning disc
Press and hold the button to start the descaling program
Continue to refil the watertank as necessary until the descaling light goes off (This can take over an hour on a Bosch machine - or about 20-40 mins on a Bruan).
Oct 29, 2009 | Braun Tassimo Espresso Machine/Coffee...
Saeco Vienna: water does not go through to the main unit
on the brew unit the plastic screw that hold the filter mush be loose or broken check that out pierre
May 20, 2008 | Saeco Caffe Charisma Espresso Machine
deacaled it use a special descaler produit not vinegar 1 part descaler 1 part water fill up water tank start let it drip for few second turn off leave it for 15 minute repeat untill empty after rinse very good very corosif stuff that descaler the machine is gonna work fine the brown stuff should come of but coffe is like dye calcium in machine is a killer brown stuff is not nice but the coffee is great cheers
Feb 03, 2008 | Coffee Makers & Espresso Machines
Gaggia 74845 Platinum vision coffee maker Coffee Maker Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
