Question about Goodman Heating & Cooling
Furnance goes on won't fire - Goodman Heating & Cooling
    Genius:
  • Goodman Master
  • 1,033 Answers
Hello, if the burners do not fire at all there could be a few reasons, the igniter could be bad, the burners could be dirty not allowing gas to flow, the pressure switch could be open. There should be a led light code on the control board that will tell you where to look. Begin by checking the hose between the inducer motor and pressure switch, it could be loose, kinked, or have a obstruction in it such as water not allowing the switch to close, also check the flue pipe for any obstructions. If the switch checks out good than the igniter should be inspected for any cracks or white spots, this is a sighn that the igniter is weak and should be replaced. If the igniter is good then clean the burners.
Posted on Mar 15, 2011
Keeprite furnance showing 7 flashes blower fan on no fire inside furnance
Limit Or Rollout Switch Open--Requires Manual Reset.
Read Sticker On Unit--Codes Are There.
Mar 07, 2015 | Heating & Cooling
Furnance fan works,but the burnrs won't ignite
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace and look in the small peep hole in the lower blower door and see if there is an led light that is flashing a certain number of blinks record the number and look for a diagnostic chart on the inside of the blower door or the upper side panel of the furnace if there is no flash code present you can try resetting the power to the furnace and see if the furnace will fire up.
Sep 19, 2011 | Heating & Cooling
To what terminals do the two wires coming from the a/c unit connect to on the furnance?i have r w g y c on the furnance board. its a carrier tech 2000 a/c and a rheem criterion 2 furnance
The 2 wires that come from the outside unit will connect to the Y(Cooling) and the C(Common) terminals on the board. It doesn't matter which wire goes to either one, they both work either way. Have a good one!
Sep 01, 2010 | Heating & Cooling
Furnance not starting
Try cleaning the flame sensor. Its the most common problem on todays furances. You should clean it with a fine grit sandpaper or emery cloth once a year.
Apr 11, 2009 | Heating & Cooling
Fan in furnance
any furnace with a blower will go on your electric bill but it really should'nt draw enough power to raise your bill noticably unless it's running constantly.
Jan 24, 2009 | Coleman Propane Forced Air Heater...
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Led flashes all the time heater won't start
some how the hot and neutral became reversed,i don;t know if it happened when a breaker sparked in the box or what . i reversed the hot and neutral at the input of furnance abd it is working at this time.
thanks for your help
Nov 24, 2008 | Goodman GMS90703BXA Heater
My heater turns on the gas starts but then it shuts down
Try to locate the red and white wires either behind your thermostat or on the furnace itself. Jump them out and see if the furnace stays on. If you do it at the furnace you will need to hold the door switch down. If it runs fine, you have found your problem (the thermostat) if it goes out again, the furnace will display a number of blinks on the circuit board. Look on the reverse side of the furnace access door and there should be an Error Code chart to get you started figuring where to look next.
Nov 10, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
62 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
