Question about Maytag MER5775Q Electric Kitchen Range
Have maytag smooth top range. Everything works. The front right burner will only stay on high. It does not matter what you set the controls at it is always high. It has a small or large burner choice. Does not matter witch you choose, still high. No change. What are your thoughts?
  • davidgalb721 Mar 15, 2011
    This unit does have temperature probs on the burners. Would this make a difference in your thoughts?
  • davidgalb721 Mar 16, 2011
    Thank You! I will let you know if I need more help!
    President:
  • 1,654 Answers
In this case the burner switch needs replaced, if it works but only on high leads to the switch.
These switches operate like regular dimmer switches. By regulating the amount of electricity flowing through the switch to the burner they allow you to adjust the temperature setting, if you can't adjust it then the switch is bad. I suggest you get a new one from the parts supply and look at it and decide whether or not you need help with the replacement, they aren't hard but you need to decide and let me know, but it really is simple if you can unplug wires and plug new ones in and turn a nut to get the switch off your probably capable of this repair your self.
Posted on Mar 15, 2011
  • Dcramer531
    Dcramer531 Mar 15, 2011
    No, still would be the switch, the probes are for the surface temp lights, that let you know the surface is still hot!
Frigidaire smooth top electric stone eye stuck on high!
Yes,the switch controlling the burner is bad and must be replaced.
Oct 31, 2009 | GE Kitchen Ranges
Most smooth top elements only work on high
this is a voltage distribution issue
you would be better served to replace the
ERC
Electronic Range Control
Sep 29, 2009 | Kitchen Ranges
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the...
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Jun 27, 2009 | Kenmore 96012 / 96014 / 96019 Electric...
Ge true temp stove top burner wont stay on
dont know how old unit is or how familiar you arewiththe unit, but the burner will need to heat up and cycle off/on. no matter how high or low you set the setting it will heat to a specific temp and cycle off, if hte burner remained RED all the time the glass would crak( so dont go by appearnce of burner, the glass should dictate the temp
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Left front burner remains on high.
change the left control, it's not controlling the power in the burner
Jan 18, 2008 | Hotpoint RB787 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
340 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
