Question about Refrigerators
I have a Samsung model Rf263ers and I keep getting a load knocking sound. I appears to come from inside the back panel but it does not happen frequently, therefore it is difficult to be there when it happens. Service men have been here and nothing happens before the leave. Any ideas?
  • Refrigerators Master
  • 43,501 Answers
Here is a tip that I wrote about the clunkingor thumping in refrigerators...
Refrigerator Clunkingin back
heatman101
Posted on Mar 19, 2011
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
Samsung 52" HDTV turns on fine picture works fine but my sound isn't and it makes a knocking noise every few seconds,any idea what could be causing this
Try to disconnect all devices connected to the tv. Perform sound test. I need to know the model of your tv.check the model on back ??
Apr 16, 2015 | Samsung Televison & Video
We have a Samsung FR323TEDBSR french door refrigerator that is becoming very noisy
It sound like the fan motor is going bad. They will spin fine when spun by hand but will start to rattle or squeal when running. if it is the model I think you have the entire panel is replaced as a complete unit. This is not hard to replace. It looks like you have already had the panel out. It just has a couple wire to unclip. and clip the new one in.
May 15, 2014 | Samsung Refrigerators
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
Picture keeps going of sound stays on.i have switch of and on to get picture back
Hello, i have some method you may try.
1. Turn on your TV set, than wait whail untill picture off.
2. After picture off, try to knocking TFT panel smoothly. If you see flashing light from panel, its mean the backlight panel switched off.
Backlight panel consist of inverter board and ccfl inside the panel. If one of ccfl's burn out, all ccfl's will switched off by inverter board. make sure that the problem comes from one of these part.
Replace it.
I hope that will solve your problem.
Thanks.
Mar 10, 2011 | Samsung Televison & Video
Hi,i have a samsung washing machine,p1253.model and i keep getting a code UE,and it appears not to be spinning.....please advise what this code means and is it possible to read an instruction manual on...
Hi, UE error means unbalanced load, loosen the washing and try again, if the load is to heavy take out some of the washing and spin in 2 lighter loads.
UE Happens if you overload the washing machine.
CLICK HERE for the user manual.
Hope this helps.
(Dont forget the thumbs up if this helped)
Feb 12, 2011 | Samsung Washing Machines
Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
Jul 06, 2009 | Washing Machines
I have a front load washing machine, model #ghw9100lw. It goes into the spin cycle and as the speed increases a very loud knocking sounds comes from the machine. I took the front top and lower front...
i had a similar problem, its more than likely that something is wrong with the metal basket inside, like a broken tripod leg on the back, or mine was missing 2 screws on one of the legs.
if you dont fix and soon you will have to get a new front outer tub. if its less than 10 years old it should be in warrenty and you can have a whirlpool repair man come fix it, you will just be responsible for the cost of service call and labor, which is around 300 in itsself.
if you decide to fix it your self the front outer tub is around 100, metal tub is around 200, and if you happen to break any of the shocks trying to get them off, they are 15 a piece at appliancezone.com.
Apr 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Samsung ht-ds610 wont work at all
Loading mechanism is stuck some where in loading or unloading process.
Unplug unit form AC outlet for couple of minutes and replug back in, power up and check.
Feb 11, 2009 | Samsung HT-DS610 System
Stops mid cycle, won't spin
You need to check and see if the door-lock light is on ,if not then you have either a faulty door lock mech. or a defective solid state board in the control panel
Dec 27, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
