Question about Frigidaire ATF6000ES Front Load Washer
II have a Frigidaire gallery series GLTF4920ES3 that is turning on and off by itself. It also is turning off and on during a washer cycle some times. When I do a diagnostic test everything works but an error code comes up saying E62. I can not find this in the manual (what is E 62). The only way I can get it out of sleep mode most of the time is to turn the power off and then back on. I think it might possibly be the control board? If it is can you give instruction on how to replace and part number?
  • thedepaties Mar 15, 2011
    Would this apply even when the washer was not working as I commented that the washer turns its self on and off again when it is dormant and not even in a cycle
    President:
  • 1,554 Answers
Error code E62 (E5C) means the heatsink on the motor speed control is overheating and this is why the machine turns itself off. Replace the motor speed control board with part number 134743500.
Disconnect power then remove the screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Remove the screws holding the rear access panel to the washer's rear panel and lift the access panel off.
Unplug the two-terminal plug from the lower front of the motor speed control board housing.
Disconnect the wire harness and release the spring loaded locking tab on the side of the control board house. Lift the side of the housing up, slide the assembly to the rear to disengage the front tab and lift the assembly awayII have a Frigidaire gallery - jahn27_229.jpger base.
From the front of the washer, tip the bottom of the assembly toward the motor and slide the aII have a Frigidaire gallery - jahn27_230.jpgtween the shock absorber and the motor.
Unplug the 2 plugs and the ground wire and remove the speed control assembly from the washer.
To remove the control boardII have a Frigidaire gallery - jahn27_233.jpging should you want to visually inspect it, release the lII have a Frigidaire gallery - jahn27_234.jpgnd at the top and lift the back open then lift the board out.
Let us know if you need further advice. Please accept the solution should you find it helpful or informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Mar 15, 2011
  • Jahn27
    Jahn27 Mar 15, 2011
    It still applies. You can verify this by disconnecting the motor speed control board. It is indeed faulty if the machine stops turning on and off during a cycling or dormancy.
Frigidaire Gallery GLTF4920ES3 Front Load Washer keeps powering off and on during a cycle. The LED panel goes crazy when it's off, no error codes, just a horizontal then vertical line and random cycle...
To get a diagnostic code out of this take the screws off the lid. There should be a manual on this model. You have to hold start and cancel together with the machine off, but plugged in for 5 seconds on this model. If you had a long fill problem on this unit the machine clunks out and doesn't operate correctly. Refer to that tech sheet to see how to reset the error codes on the unit and try again. If your machine has 8888 display instead of just little led lights, the error codes are much easier to read and understand through the tech sheet. To put the unit into diagnostic mode, you have to set the dial all the way to the specified cycle setting and follow the instructions from there. It will throw only an error code if you hold Start and Cancel together.
May 19, 2014 | Frigidaire ATF6000ES Front Load Washer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery Series Frontloader no final spin
I had the same problem. Here's a link that might help:
http://applianceguru.com/forum2/2937.html
I removed the hoses and pump and found the filter in the hose leading from the washer was clogged with a shoelace, $2.35 in loose change and a few GI Joe issued M4's. :-) Once I pulled that filter out and cleaned the **** the washer runs like a champ.
Apr 30, 2009 | Washing Machines
Our dishwasher is not running through all cylcles
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Dec 02, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire gallery series FDB125ORES1 wash light blinking, dishwasher won't cycle on.
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Aug 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire ATF6000ES Front Load Washer Logo
368 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
