Question about HP Media Center m1080n (PC099A#ABA) PC Desktop
Any small CPU cooler could fit into this crow space computer?
I had been try to buy a quieter CPU cooler for this computer to get rid of the intolerable noise it made. But turn out this crow space computer can't even contain a 92mm cpu cooler like this one (Thermaltake CL-P0370 92mm Enter CPU Cooler )
So does any one can recommend me a small cooler that can fit into this computer? By the way I heart about people say some computer support change cpu fan speed in BIOS. Is this computer support this feature? or any
  • HP Master
  • 5,660 Answers
That Thermaltake Cpu cooler you show is HUGE! Not surprised it won't fit! lol! It's 117mm Long x 102mm Wide x141mm Tall.
That's about 4-1/2 inches Long by 4 inches Wide by 5-1/2 inches Tall!
Suggestion for CPU cooler? Hmmmm, how about a ZEROtherm CF900? It's 100mm Long X 94mm Wide X 77mm Tall.
Here's the PDF file download for it's installation guide,
http://static.tigerdirect.com/pdf/Zerotherm_CF_Series_Cooler_Manual.pdf
Here's on place I found it on a quick search,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2882724&CatId=493
Speedfan is a software many people use to control CPU fan speed,
http://www.almico.com/speedfan.php
Perhaps you should try it. To change your fan speed in your BIOS Setup utility, you access BIOS Setup, and look in Advanced BIOS options. See if this option is there. I would use care, hence why I posted Speedfan instead.
Posted on Apr 10, 2009
Want to make my fan quieter
This is not something you want to mess with ..cause the fan is crucial for the safety and function of the laptop ..The fact that its loud it indicate the cpu is used excessively ..and its temperature rises to the limit . If you want ..you can open it up ..and install a better cooler for it ..or if it has the space ..and you see on the internet a upgrade for the cooler ..you can buy it and install it ..This will not make it silent for good..but a better heat dispenser will dispense the heat more efficient and he cooler will have no need to kick in and make all that excessive noise..
Another thing you can do for to protect and avoid the noise ..is to buy a external heat dispenser..-cooler ..and use it..These are some kinda frames with a extra cooler and your laptop will fit into it ..and the cooling will be permanent so it will not sense the need to start the internal cooler at the max speed.
Just look over the net and take a look for some models ..
another thing ...if you want to upgrade the heat dispenser ..make sure it will fit for your model ..(the hit dispenser (internal ) it is a aluminum piece in which the fan is located..and have the function to get the heat from the cpu itself ....its job done better ..will basically reduce the cooler intervention but in excessive use..
Nov 29, 2011 | Acer Aspire 5315 Notebook
Hi my Acer T180 cpu fan is very loud. Will I be able to replace this with a quieter one?
Yes, it's a standard AM2 cooler that you can replace yourself. Just make sure the one you will buy will fit on the board - the space is limited on the sides so a cooler with horizontally raised fan will be the best. One like
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6101294&CatId=2545
Aug 11, 2011 | Acer Aspire™ T180 PC Desktop
System.hardware.vendor = 'Packard Bell NEC' system.hardware.product = '00000000000000000000000' system.hardware.version = 'PB13109001' system.chassis.manufacturer = 'NEC COMPUTERS...
you need a new CPU cooler and the part you will be needing is called 'CPU COOLER". Go to any computer accessories shop/store within your vicinity and purchase another CPU cooler. You will need to remove the one from your motherboard and use it as a sample to get another one so that you can get exact size of cooler that will fit your CPU because CPU coolers varies in size and shape.
Good luck.
Aug 03, 2010 | Computers & Internet
What kind of CPU coolers are compatible with HP Pavilion a1710n?
That's a hard question to answer, you need to fine out what CPU you have inside and then look up CPU coolers for that CPU style. Since your using a pre assembled machine you may have a specialized hole pattern making an aftermarket cooler hard to find. and use.
Jul 29, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Anyone have any idea what type of cpu cooler?
you could try koolance they make excellent water coolers. i own the 750 myself. if this helps please rate this.
Mar 24, 2010 | Microsoft Systemax SG 1150 Gaming Desktop...
My heat sink got dirty and caused a thermal event alarm (overheated) the computer will shut down when the cpu is taxed. do i need a new cpu
No, if the computer will start and it run bios screen and boots into windows
the cpu is fine, you need to get a better cpu cooler.
Buy a better cpu cooler for your socket, coolers are designed for the Socket that the processor plugs into.
Go to Newegg.com and llok for a cooler, you will see reviews by people
and if they liked the cooler, there are little eggs next to the product
is it has high ratings, you will see what I mean when you look at the site.
The page I posted is already on the cooler page, just llok to the left side
and look at sockets and pick your socket out to look at coolers for your system.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
Feb 07, 2010 | eMachines T3516 PC Desktop
Loud fan noise
have one very similar, they only have a fan in the power supply, and a small, small fan on the CPU. If it's the fan in the power supply making the noise, some people would say replace the whole unit, some would say replace the fan. I would replace the fan, but if you don't want to take the risk of getting electrocuted, that's probably a great idea. A power supply can be found somewhat cheaply, but one that fits those cases might not be quite as easy.
Jun 09, 2009 | HP Pavilion 515n (DC471A#ABA) PC Desktop
Finding a cpu cooler replacement for motherboard with screwholes.
You should be able to purchase a cooler that fits your existing cooler plate.
Replacing a cooler can sometimes be a lot of work. Sometimes you have to remove the motherboard from the case and remove the cooler plate from the underside of the motherboard. Then coolers that use "just the holes" can be used. Or another (different) cooler plate can be installed that may have came with your new cooler. In my experience, the coolers that use "just the holes" (no plate) leave a lot to be desired. Plus, if you're not careful, you can damage the motherboard by applying too much force when installing the fan. If you use a new plate, don't forget to install the insulator between the motherboard and the plate, if it comes with one.
Be careful to protect against unwanted electrostatic discharge. Always touch the metal computer case before touching any parts inside the computer. Also, if you remove the mobo, take careful note of where all the wires go before disassembly.
Feb 13, 2009 | Gateway 838GM (RB838GM) PC Desktop
How to change
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Oct 31, 2008 | Intel Socket 478 CPU COLLING FAN & HEAT...
HP Media Center m1080n (PC099A#ABA) PC Desktop Logo
198 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
