Question about Eliminator MotoMaster Mobile Power Inverter 700w
I have the 1200W Eliminator. When the switch is turned on the fault light comes on as well. The cooling fan does not start up and there is no power at the plug in's. I took the panel off and the 30 amp fuses appear to be fine. Internal components visually look healthy. Nothing charred or discolored.
2 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
Posted on May 20, 2010
Blinkin light
Turn the main power to the unit off, leave off for about 20 seconds then turn back on. Unit should restart. The blinking light is a fault light that can be reset by turning main power off. Most times it will restart no problems but if the fault re occurs there is a problem with the unit itself. If the fan starts and runs for around 4 minutes on cooling mode then stops and blinks there is a problem with the outdoor unit.
Mar 31, 2014 | Daikin Mini Split Ceiling Suspended Units
No electrical power to AC Compressor. The switch light comes on in car when AC power button is turned on.
  1. Check if air blows with the fan setting turned to high.
  2. Check that the radiator cooling fan engages when the A/C button is pressed.
  3. Locate the compressor.
  4. Turn on the A/C.
  5. Check if the compressor's clutch has been engaged.
  6. If the clutch engages, the fault is elsewhere.
  7. If the clutch does not engage, check for power to the clutch.
These steps might help find the problem.
Sep 16, 2013 | 1997 Ford Escort
Cooling fan wont come on car running at a high tem
You could verify fan motor is good by using jumper wires from battery to the fan motor. If the motor is good, you will probably need a wiring diagram and at least a test light to start checking the fan circuit. There will be a cooling fan relay that when signaled, will send power direct to the fan. The signaler to relay to turn the fan on may be the engine computer when the coolant temperature sensor tells it engine is getting too hot- or it may be signaled on by a fan temperature switch mounted in the radiator. When coolant reaches a set temperature the switch closes contact, and the relay is energized to pass power on to the fan. One could pull the relay and with key on, use test light to probe the terminals where relay plugs in. The power feed for the fan should light up the test light on one of the terminals, verifying power is still available to turn the fan on. Next one could check if the signaler to turn the relay on is working.
See? So you do need a wiring diagram to see how the circuit is wired. But the first step is to verify fan motor is good. Good luck, Nigel.
Aug 27, 2013 | Vauxhall Cars & Trucks
Sanyo Projector PLC XU83 lamp is replaced 1 everything is fine 2 projector turned on and reset the counter 3 projector switch off and normal 4 Next time imposible to power on the projector After ...
Check the cooling fans. If they are not rotating the Projector will not start.
Did the lamp explode? If it did a bit of glass has lodged in the cooling fan and stopped it from working.
Hope this helps.
Nov 15, 2010 | Televison & Video
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Electric Radiator Fan Does Not Come On
Chevy dealer says will not come on until temperature reaches 219 f
May 16, 2010 | 2007 Chevrolet Silverado 1500 2WD
I have 1750w mobile power inverter turn on light comes on then the falt light come on right away.
Like most Cheap square wave inverters, the mosfets can not take the inrush current.
Usually if the fault light comes on and there is NO voltage at the output, FIRST check the on board fuse, then check for any tell-tale burn spots, or areas where the components have heated up or burned.....if you get this far and all appears clear, then it is time to check the fets.
I would not reccomend any Motomaster Eliminator inverter other than the more costly sine wave unit....or stay with a 1kw unit and do not overload it.
It\s best to run as much as you can at 12vdc or higher...like 24vds. AC is nothing but problems.
Apr 10, 2010 | Eliminator MotoMaster Mobile Power...
Heat would not come on and fan would not cut off even when thermostat was set to off. Took off the outside panel of the unit and red light was blinking 7 times - rollout switch fault. Since fan would not...
this means that the rollout switch was tripped by a flame coming from burners. could be a plugged fue or bad inducer motor, or a bad rollout switch. the fan will not shut off as a safety feature it keeps running incase the heat exchanger is to hot to keep a fire from starting. it will shut off after disconnecting power and restarting everything. watch the flames from burner when it lights to see if the actually roolout of the burner box toward the rollout sensor.
Dec 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
The fan on my 1200 watt inverter does not start when turned on.
No. the fan is to remove heat(obviously) If there is a small or no load on the inverter the fan wont come on(no heat to get rid of)..........this is so a lightly loaded inverter wont kill your batteries as fast.If you load it up(power something big or power several things at once) the fan should start after a few minutes
hope this helps.Good Luck!
Dec 13, 2008 | Whistler PI-1200W 1200-Watt Power Inverter...
Cooling fan in reciever noise.
Its necessary to run cooling fan because Amplifiers in home theater system produce heat during its operation. If you shut down cooling fan, Amplifier ICs may be damaged due to over heat.
Aug 24, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Eliminator MotoMaster Mobile Power Inverter 700w Logo
644 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Tom Chichester
Bill Boyd
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
