Question about Kobe IN2636SQB Stainless Steel 32" Kitchen Hood
The electrical system shorted out when a light bulb broke while changing it. The circuit breaker did not trip. None of the electrical system works. Is there a fuse to replace? Do I need to replace the computer?
    Genius:
  • 1,075 Answers
You need to replace the light fitting holder as this is the reason the system failed.As to why the circuit breaker failed that is a mater for an electricion,because i would suspect a majour fault on the home electrical system.adrian.
Posted on Mar 15, 2011
I have changed Batteries in the hand-held remote but no response on system or light for our pool.
following these steps
1. double check the batties
2. to go remote and double check to make sure that it getting electric
3. double check the circuit breaker, sometime you have to throw the switch off then on again if it tripped.
4. Call a electric you might have a bad circuit breaker or a short.
Apr 07, 2015 | Televison & Video
Where is the breaker or fuse for the oven light ?
Check for a tripped breaker in your power panel for the house. There's where the breaker for the oven is.
Nov 19, 2014 | Kitchen Ranges
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
Light trips breaker
I would check for a short to ground. Check all wires for nicks. I don't think the ballast would cause this issue. It is a bit strange that you only have the one light on the circuit.
May 20, 2013 | Home
My e wave microwave appears to be in fine working order until the door is opened. It then trips the breaker and ceases working. Ater the house breaker is reset, the power is restored to the microwave...
You may have a short circuit on the INTERIOR LIGHT BULB circuit in your microwave.
This might explain why the breaker trips every time you open the door.
If so, you would have to unplug and disassemble the unit in order to access the wires and light bulb socket inside the case in order to troubleshoot and repair the problem.
If you are unfamiliar with safe electrical troubleshooting and repair procedures, please be extremely careful or consider hiring an electrician to do the work. There are some hazardous components inside which remain dangerous even after the unit is unplugged.
Good luck.
Apr 19, 2011 | Vacuums
When I flip the manual switch it clicks but the lights wont turn on.
Manual override should turn lights ON-OFF even if timer has gone bad.
It sounds like problem is electrical.
Suspect line-up:
Test that timer is getting electricity from breaker.
Burned out bulb. Change bulbs. Spray WD-40 on bulb threads before installing bulb.
Outdoor wiring can go bad easily, outdoor bulb sockets become dirty and stop functioning.
Loose wire between breaker and timer -or- between timer and lights.
Loose wire inside timer box. Tighten screws.
Loose wire on circuit breaker. Tighten screw on circuit breaker.
Tripped circuit breaker: click circuit breaker all the way one direction and then all the way back other direction.
Bad circuit breaker. Move wire from one breaker to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
1996 harley 883 headlight flickers off real quick every minute or so with a clicking sound and my front and rear blinkers are dead. I turned it off and pulled out the key and it still made the clicking...
You have a short in your electrical system somewhere that is causing your circuit breaker to trip. Harley uses automatic reset circuit breakers rather than fuses. If you get a short in your system somewhere, the current though the circuit breaker will cause it to trip. After a minute or so, the circuit breaker's bi-metal strip inside will cool and the circuit breaker will reset. If the short circuit still exist, the breaker will again trip.
To help find the source of the problem, you must determine which circuit breaker is tripping. In this case it sounds like the "lights" circuit breaker. Since your turn signals are on that circuit and they are not working, I'd start there to look for the reason.
When you turned off the key and it made the clicking noise again, this was probably the circuit breaker resetting itself after you removed the voltage and current flow through it by turning the switch off.
Good Luck
Steve
Jan 04, 2011 | 2000 Harley Davidson XL 1200 S Sportster...
I was changing a light bulb with one of those metal extension rods that unscrew and screw back in the replacement bulbs. It evidently didn't seat correctly and pulled off the bulb and created a quick...
If you have not already done so, I would check at the fuse or circuit breaker panel to see if you have blown a fuse or tripped a breaker.
Aug 28, 2010 | Vacuums
I have a 15 amp single pole circuit breaker that
It could be either or at this point. First thing to do, is unplug all electric devices from the plugs on that circuit, and then attempt to reset the breaker. If it does not trip, one of the devices plugged into a receptacle on that circuit could have a short. If it doesn't trip, plug each device in one at a time to see it it trips the breaker to pin point what is causing the short. If the above has no effect, I recommend replacing the breaker. It is easy and inexpensive to do. Just make sure you main is shut off before doing any work on the panel. I hope this helps and good luck!
Nov 06, 2009 | Connecticut Electric & SWITCH UBIP130...
Kobe IN2636SQB Stainless Steel 32" Kitchen Hood Logo
177 people viewed this question
Top Kobe Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kobe Kitchen Range Expert? Answer questions, earn points and help others
