Question about ASUS DSL-N13 Wireless Router
PROBLEM WITH ASUS DSL-N13 ROUTER, ALL 4 LAN PORTS ARE BLINKING FAST BUT HAVE NO LIGHT ON POWER, DSL.IP.USB, WIFI ALL LIGHTS ARE OFF. DID TRY TO RESET, DID UNPLUG THE POWER BUT NOTHING IS HELPING . IF YOU HAVE A SOLUTION, PLEASE HELP ME..... THANK YOU VERY MUCH
  • 1,591 Answers
Disconnect everything from the unit, then reconnect power.
If the unit behaves normally, start plugging things back in until it goes nuts again.
Whatever you plugged in last is the problem.
If the unit behaves the same, either your power adapter is failing (use a volt meter to check) or the router will need to be replaced.
Posted on Mar 15, 2011
Testimonial: "YES, YOU ARE RIGHT... THE 12V POWER ADAPTER IS BAD..... IT IS FUNNY, I HAD JUST 3V AND IT MADE THE LED'S BLINK FAST. THANK YOU VERY MUCH FOR YOUR HELP"
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
My next book can't connect to WiFi because Mac and IP address is unavailable. What do I do
1) Turn off your netbook
2) Power off the router by unplugging it
3) Power off your cable or DSL modem (if different from your router) by unplugging it
4) Power on your cable or DSL modem and wait for the blinking lights to "stabilize" a bit
5) Power on your router (if different from your cable or DSL modem) by plugging it in and wait for the lights to stabilize a bit
6) Turn on your netbook
7) Test connectivity
Feb 01, 2015 | Computers & Internet
Error 045 when setup the modem with Win7 64 bit, connection to network failed.
What the problem? i'm also using this router...
how you setting the router?using wifi or LAN?
BEFORE THAT,
DOWNLOAD HERE
RUN INSTALLER FIRST BEFORE CONNECT TO YOUR ROUTER.
connect line rj11 to link dsl,rj45 to your pc/laptop.(dont use wifi to setup the router)
then plug the power and ON the wifi router.
After that, check light for ADSL, WLAN INTERNET AND PORT(1 OR 2 OR 3 OR 4) IS BLINK
..IF light is okay and blink, then you can setup the utilities.
Is easy. TP-LINK get ready with software that you can setting the router as like professional with the secure encryption. For receiver I'm preferred you using tp-link also. Then you can use QSS function only just click button QSS..
May 27, 2011 | TP-LINK 300Mbps Wireless N ADSL2+ Modem...
We had to have at&t reconnect our dsl service. we had disconnected the Linlsys now we can't get it to work.Help please
Turn the DSL modem off.
Turn the Linksys router off.
Turn your computer off.
Check that all the cables are correct & are connected:
* 2-wire or 4-wire cable between telephone wall-port and DSL modem;
* 8-wire cable between DSL modem and the WAN (or 'Internet') port on the router;
* 8-wire cable between one of the LAN ports on the router to the network-port on your computer.
Turn the DSL modem on, and wait until its blinking-lamps settles down to a repeating pattern.
Turn the router on, and wait until its blinking-lamps settles down to a repeating pattern.
Ensure that the lamp for the WAN connection is on.
Turn your computer on, and let it boot.
Ensure that the lamp for one of the LAN ports on the router lights up as the computer is starting.
After your computer has booted, your router should have assigned an IP-address to your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
You should see an IP address like '192.168.xxx.yyy' for your computer,
and a similar IP-address for your "default gateway".
If you see an IP address like '169.254.xxx.yyy', then your computer has *NOT* obtained a *valid* IP-address.
Also, your router should have obtained an IP-address from your ISP (AT&T),
and you should have Internet access -- try to access 'www.CatsThatLookLikeHitler.com' (or any other web-site).
May 05, 2011 | Computers & Internet
I am trying to connect netgear router to my modern ATT can you help me out?
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Jun 08, 2010 | NetGear WGT624 Wireless Router
Installing a netgear router
It seems that you need to reconfigure router ,you can use following steps to reconfigure router
16. Click Apply.
May 17, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Netgear wireless-N 300 router directions
Direction for using and configure router
16. Click Apply.
Hope it can resolved your query
Thanks for using Fixya
May 05, 2010 | NetGear WNR2000 Wireless Router
NETGEAR wirless router installation
You can use below steps to install router
ROUTER SETUP
3. Put http://www.routerlogin.com/basicsetting.htm or 192.168.1.1 address bar. press enter
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on lan ip setup under advanced.
6. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
7. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
8. Power off the dsl modem and the router after making the connections.
9. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
10. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
11. Access the router (http://192.168.10.1).
12. Login to the router (Username = admin Password = Password).
13. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
14. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
15. Click Apply.
16. Logout of the router.
17. Open up another browser window and try to access internet.
Please rate the service positively if issue resolved
Apr 04, 2010 | NetGear RangeMax WPN824 Wireless Router...
How do i hook up my netgear wireless with out the cd
Now please follow the steps to configure the router:
5.Login to the router (Username = admin Password = Password)
6. Click on lan ip setup under advance.
16. click Apply.
regards
prakash
Mar 18, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
I am trying to configure my netgear router to work with my dsl motorola modem
You can access your wireless router by first running you ethernet cable from pc to wireless, then in address bar, type 192.168.1.1 and this will enter the wireless router's software. If it asks for username and password, try typing admin for both.
Sep 03, 2009 | NetGear WGR614 Wireless Router
ASUS DSL-N13 Wireless Router Logo
528 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
