Question about Echo Garden
How can I trouble shoot the kill switch on a echo weed eater. The spark plug is good as it has ben tested on another machine. There is no spark and seems the kill switch should be the next obvious thing to check. Then the Coil?
    President:
  • Echo Master
  • 1,545 Answers
Check the kill switch terminals with a continuity tester (small multi-meter will work). If the switch is Ok and there is no spark, take off the engine cover and check the "air-gap" between the magnets in the flywheel and the ignition module legs.The closer the better, but you want about a ,008-.010"gap there...about the width of a standard sized business card. Metal feeler gauges "stick" of course to the magnet area in the flywheel and throw off clearance sensitivity. Try it with a business card. If not in range, then loosen the coil screws, double the card over, and let the magnets pull the coil legs into the card...retighten screws and check for spark.
Posted on Mar 15, 2011
Echo 266 weed eater will not start
Hey George,
I would get a new spark plug, and have the "shop" clean and set the carb.. (if you know a really good motorcycle/ATV mechanic - they can clean and set it)..I work on some of these occasionally for friends.. it will be fine.unless there is internal damage...
Sep 11, 2017 | Echo Garden
Why weed eater wont stay started
  • #1 - Change Fuel Filter
  • #2 - change or clean Spark Arrestor
  • #3 - Change or clean Spark Plug
  • #4 - Clean carburetor
Order of importance, Start at #1 and work forward.
Look here...
Jul 22, 2014 | Echo Garden
No spark on Weed Eater FB25 25cc Gas Blower
Test the kill switch first, disconnect the kill switch and see if you have spark. Then the kill switch is not working or is grounding out. If not, the problem could be the ignition module.
Mar 16, 2013 | Weedeater Weed Eater Fb25 25cc 2 Stroke...
Echo weed eater not getting any spark?
Remove plug and lay plug base against the cylinder or jumper plug base with jumper wire or battery jumper cables to the cylinder and pull starter cord and see if you have spark on plug, you may have to darken room as some sparks are very hard to see in light. If you have no spark would check the ignition switch by removing wire and make sure the wire does not touch metal. If you still have no spark you probably have bad coil that is if this is not a point type ignition system in which case it could be dirty or pitted points. Would always help if you give model no. When asking questions which we could look up type of machine.
Oct 06, 2017 | Echo Garden
No spark to plug on the WEED Eater Featherlite 25 HO SST. Coil looks good. Conncetions to stop switch good. What am I missing?
Make sure you are testing for spark with an inline spark tester. This type of test will connect between the spark plug lead and the plug itself. If no spark, then disconnect the wire(s) from the ignition module...don't just disconnect them from the switch. Now retest. If still no spark, then the ignition module (coil) is faulty and will have to be replaced. If there is spark with the wires disconnected, then there is a short in the wires leading to the switch or in the switch itself.
Aug 31, 2010 | Poulan Garden
Weed eater won't start. changed spark plug,
possibly on/off switch-has it gotten wet? Also check where wiring from on/off switch meets the wiring from the weedeater body.Check those connectors/crimps make sure theyre plugged in /right fit and not wet.Make sure youre ground wire is grounded/attatched/screwed to the machine.Ive had a weedeater get wet twice at the on/off switch and had to bring it in the A.C. overnight to really dry out.It worked.Hope this helps.If none of this does then its maybe the coil(semi-internal-no fun) or the fat wire carrying the spark from the plug to the body(semi-internal-no fun).Good luck!
Jun 28, 2010 | Garden
ECHO 2000 WEED EATER I changed the fuel line,
You may need the carburetor adjusted or rebuilt. The other possible item is "bad gas". If the gas has been sitting around longer than 30 days, it may be time to mix up some fresh fuel mixture.
HTH
Good Day.
Oct 29, 2009 | Garden
I have a snapper S31SST weed eater. It is 4-5
Remove spark plug and check for fire with a spark tester. (some inline models are also available and safer since the spark plug stays in place using those types)
If no spark:
Remove covers and unplug small kill-circuit wire(s) from ignition coil...Test for spark.
If you have spark the switch needs replacing.
If you have no spark the coil needs replacing.
Hope this helps.
Sep 26, 2009 | Garden
Echo Weed Eater bogs down.
Echo carbs have a little black plastic plug covering the High speed adj screw..CA air pulotion control bs..So get that little black blug out and give the screw a little turn open and u should be good to go..It worked for me..on a PBL 251 blower..My Echo weed wacker has the carb also..Go to Echos site and download the parts break down for your unit and look at the carb page..You will see the plug and HS,screw..happing wacking and blowing
Jul 05, 2009 | ECHO, Inc. PB-251C Handheld Blower
I have a an echo srm 3100 weed eater that won't start. I bought a new spark plug and when I pull the starter rope it is not creating a spark. This occurred after starting it up for the first time this...
Well, if you have made sure that the kill switch wire isn't grounded somewhere, then it is probably the ignition module (coil). But before you buy a new coil, try sanding the side of the flywheel and the metal piece that faces the flywheel, (this is part of the coil).
Jim
Jun 07, 2009 | Echo Garden
Open Questions:
Garden Logo
899 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
