Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Cant log in give aoff-86 error code - Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Error 86:01
HP has a detailed solution with pictures: http://h20565.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/mostViewedDisplay?javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken&javax.portlet.prp_efb5c0793523e51970c8fa22b053ce01=wsrp-navigationalState%3DdocId%253Dmmr_kc-0104514-13%257CdocLocale%253Den_US&javax.portlet.tpst=efb5c0793523e51970c8fa22b053ce01&sp4ts.oid=4214021&ac.admitted=1385252935149.876444892.492883150
Nov 23, 2013 | HP Designjet T1100ps Printer
Hp designjet t1200 error code 80
80 ......... there is more to error code than just 80 please give full error code details for a useable solution .
eg 86:01 ( carriage motor transport error)
or 0c00340a is also a fault code
if you can supplye either full error code then I will attempt to help you resolve it thanks
Oct 07, 2013 | HP DesignJet Office Equipment & Supplies
Change base log
The TI 86 has two logarithmic functions: natural logarithm (ln) and common (decimal) logarithms (log). If you need the logarithm in any other base than e or 10 you need to use one of the two equivalent expressions
log_b(x) =ln(x)/ln(b) =log(x)/log(b)
Here b is the value of the base of the logarithm and x is the argument (the value whose logarithm you are seeking). Of course the argument x must be a positive number.
Note: On the TI 86 the log function can calculate the logarithm of a complex number, according to the manual.
Sep 22, 2013 | Texas Instruments TI-86 Calculator
What button do you push on the TI-86 calculator to do the inv log function?
For the inverse natural log, press 2nd LN. For the inverse common log, press 2nd LOG.
For example, to calculate the inverse natural log of 2, press 2nd LN 2 ENTER and you'll get about 7.389 .
Jan 25, 2011 | Texas Instruments TI-86 Calculator
Cant get into windows. Not in safemode or any mode. After rebooting and before going to windows a quick blue screen with error codes pops up and go back to choices on how you would like to log back to...
Put the error code in google and it will give u a picture of what exactly is going on the computer.
Most probably u shouls reinstall your OS.
Nov 10, 2010 | Computers & Internet
I cant open a web page or home page it give an error message requeting ssid code or name
Sounds like your phone isnt connected to an internet access point. SSID would be brodcast from a router. Make sure your WIFI is broadcasting and log on to the network.
Sep 26, 2010 | Cell Phones
My dell pc only gives me a blue screen and i cant log onto windows vista i have a error code STOP : 0x0000c1F5 can you help
I found this article that relates to your specific problem. It looks like there is a hotfix.
http://support.microsoft.com/kb/946084
Nov 21, 2009 | Dell Dimension 4600 PC Desktop
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
126 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
