Question about Microsoft Computers & Internet
My PC always gets this "checksum error" ..."date
  • 1,591 Answers
Are you inserting the batteries with the totally flat side up and button side down?
And did you remember to put the clear cmos jumper back where it was, because if not, not only may you have damaged the unit, but that is the only explanation I can see for draining the battery like that.
The PC should never be powered on while the cmos jumper is in the clear position.
Posted on Mar 15, 2011
A 1xx POST error code indicates a problem with the ??
It indicates a problem with the system boards. For more info, start here.
Oct 30, 2012 | HP Computers & Internet
When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
Sep 14, 2011 | Asrock P4I45GV...
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
Always start up with cmos checksum error, cpu ratio has been change
A BIOS checksum error is most likely caused by a flat BIOS battery.
Replace the battery with a new one (it is usually a coin size battery - type CR2032) and then boot up and go to the BIOS configuration and set the Date & Time setting etc.
Jun 30, 2010 | MSI K8MM-V Motherboard
Just bought this Samba 1845 system. Upon power on receive bios rom checksum error, insert system disk. Is the battery dead, bios need to be flashed again, please help
A BIOS sum check error is usually due to a near flat BIOS battery.
Replace the BIOS battery and configure the BIOS Date & Time setting etc.
Oct 27, 2009 | FIC Samba SM-1845 (SM1845GV) Barebone
How can i resolve a bios checksum problem with my hp pavillion dv 2000 laptop
A BIOS checksum error is usually related to a near flat BIOS battery.
Replace the BIOS battery then boot up the laptop and go into the BIOS configuration and set the Date and Time settings etc. and the checksum error will disappear.
Oct 22, 2009 | HP Pavilion dv6000z Notebook
CMOS CHECKSUM BAD USB DEVICE OVER CURRENT STATUS DETECTED SYSTEM WILL SHUT DOWN IN 15 SECS there is no shortcircuit in usb header 5v is ok i also upgrade bios but it did not solve this error
easy......cmos checksum bad =
dead battery ...buy a new cmos battery for £2 ..make sure you install correct way up...
from any pc shop or ebay...
you will have to reset date /time in bios afterwards...f2 or delete usually to enter bios settings..
regards tonster
Apr 05, 2009 | ASUS P5RD2-VM Motherboard
I got a thinkpad 2635 yesterday from a friend and upon powerup it displays an error message with 00161 and 00163 printed under it with two options ok and cancel what do i do to get into this thing
These error message relates to the BIOS and it appears the BIOS battery requires replacing because it is flat.
error 161 usually BIOS has lost its configuration/ checksum error.
error 163 usually BIOS clock not updating.
Replace this battery and go into the BIOS setting and configure the date/time settings, and hardware settings (if you are not sure select the factory default settings) save and exit
Dec 12, 2008 | IBM Thinkpad T20 Notebook
CMOS checksum bad
Check your battery connections sometimes when you change battery the connectors get distorted and do not connect properly.
Also check all M/board power conections
Nov 04, 2008 | EliteGroup P4M800PRO-M Motherboard
Computers & Internet Logo
78 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
