Question about Cameras
My Panasonic Lumix DMC-FX01 takes great pictures outside, but inside they turn out too yellow or red or very grainy.
    Scholar:
  • 83 Answers
Sounds like the flash is not enabled-make sure it's set to "auto" and not disabled.
Hope this helps,
Raf
Posted on Nov 05, 2009
Please provide the service center number and address
Posted on Nov 05, 2008
Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Aug 23, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Lost Lumix simple viewer C D for Panasonic Camera DMC FX01
If you are looking for drivers in that CD, click Panasonic Support and check drivers list of DMC-FX01 at bottom of page.
and if you need Software CD, please contact nearest Panasonic service center.
May 15, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
When I zoom useing my panasonic lumix DMC-FX01 it turns off
Have you had problems when you turn it on and off from scratch before? It sounds like you have a problem with the lense extension. Now if you are lucky, it's just a bit of dirt in there and the best cure (I know, it sounds horrible) is to put the end of a shop-vac over the lense when it's closed and it will probably **** the obstruction out. If you are less lucky, the problem is with the gearing inside and in the middle of the luck-vs-effort range it could just have been bashed, in which case, you can try and push it back into alignment but be careful with it (he says, after he hit his last one with a large lump of wood to put it back).
Good luck :)
Apr 05, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
The lcd of my Panasonic Lumix DMC-FX01 became grey when i was taking photos. There is no problem with the photos though. The camera works without any problem. The problem is that the lcd is grey and i...
pls try to reset the camera to factory settings
performa a software reset via the menu's using the settings on the 'play' setting on the dial
if it doesnt help then
u can buy screen here and get it fixed or u can fix it is a jack mechanism inside the camera no soldering work it is not that much technical inside these devices all things are with jacks and flex cables and grips so u can do it see the link below for replacement screen from ebay and u go repair it if u go to a repair shop or panasonic they will charge u 200 $ for a 200 $ camera so dont attempt it PLS RATE ME FIXYA for help and one thing more u can check the flex cable and the connector of lcd to board may be it has some condesation and re seating might help bcoz ur LCD is not damaged as u told me no impact not broken so it might be a faulty flex cable
http://cgi.ebay.com/PANASONIC-LUMIX-DMC-FX01-FX1-LCD-DISPLAY-REPLACEMENT_W0QQitemZ220371657188QQcmdZViewItemQQimsxZ20090304?IMSfp=TL090304123003r38786
pls dont forget to rate me FIXYA
Mar 20, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Mar 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
sir, it's a mechanical lens movement problum this is repairable
Dec 05, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
DMC-FX01 Flash Does Not Work
In what mode are you trying to take photos? The flash will not work in certain modes (see the manual), for example the night mode. Or you accidentialy turned on sequential/burst mode (this is mode where camera takes more pictures on one shutter button press). Flash cannot be used in this mode also. I don't have FX01, but on FZ8 the camera will show flash icon in red, but will take the picture anyway without flash being triggered. The second problems seems like enabled power-saving mode, but those 5 seconds are too short for this. But anyway you can check in SETUP menu the settings for power-save. Also maybe the flash is broken and camera noticed it... I don't think this could be a software problem. Either problem with the flash, but more probably just setting of wrong mode.
Jul 24, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
Cameras Logo
153 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
