Question about ASUS Eee PC 1000H Laptop
Hello. my charger chord when plugged in for sometime quits charging my laptop. to fix this i typically unplug the chord that plugs into the charger and I also unplug it from the wall. Is this normal?
  • 902 Answers
No its not normal it means one of 3 things highly unlickly but the cord that goes from the brick to the wall is bad. more likely the brick itself is going bad, or the actual part where it connects to your pc is loose. worse case is your battery itself may be loosing the ability to charge.. hope this helps would love a thumbs up lol if that solves it.
Posted on Mar 15, 2011
Testimonial: "Thanks, it's pretty much what I thought but I'm not a big computer person so it was nice to get a 2d opinion. "
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Jan 08, 2013 | Toshiba Satellite A205-S5809 Notebook
Power does not on my laptop
This could be one of several reasons. The most common reasons that a laptop won't power up are a dead battery, or a non-functioning charging chord. My first step would be to plug the laptop into an outlet in the wall that I know for a fact works. If I am unfamiliar with that specific plug, I will plug something into that outlet that makes noise or light. Such as a lamp, stereo, or phone charger. After you have verified that the wall is giving electricity to the charging chord, the next step is to check the next step in the power chain. That would be where the chord from the wall plugs into the transformer box, that plugs into the laptop itself. So the first step is to check that the outlet that charges the laptop is receiving power. As a side not just because a top plug is getting power does not mean that a bottom plug is as well in my experience. After power received, next check connections. Those connections will include the transformer connection, and the laptop connection. Also you may wish to check for cut, loose, frayed, taped, kinked, or otherwise dangerous looking chords. I also do not recommend using third party Universal laptop chargers bought from the store. I only would use one of these in an emergency situation. I don't trust the power regulation. And on top of that a laptop charger chord is so much cheaper on-line if you buy from somewhere like e-bay. That charger will be laptop model specific. Generally a new charger is about $15-35 on e-bay, and a new battery could be as cheap as $50. Although I would also recommend finding out if your laptop is under warranty. If it is within a year old this is a good possibility. That route takes a lot of patience, but it is usually free.
Aug 31, 2011 | Computers & Internet
When I plug in my speakers, they make a constant static sound. It can become quite loud at times and I've found that turning the input chord around can sometimes work, or unplugging the charger for my...
if your speakers are near to some electronic devices you'll get theses static noises try to keep them away from electronic devices which solves it very easily..
Sep 30, 2010 | Audio Players & Recorders
How do you get this notebook to run on just the battery please?
to use or running Notebook in a battery, simply unplug the battery charger ( power chord) and your battery should be fully charged.
by the way, if ou having the problem of a laptop shutting off when you unplug the charger when your battery is fully charged, there is nothing wrong with the laptop, battery, or computer, it is a power management setting. What you need to do is:
  1. Go to display properties
  2. select the screen saver ta and click the "power" button
  3. In the power schemes tab there iss a drop down window, click it and select "Portable/Laptop" (it is a power switching utility that quickly switches between AC and Battery when the power cable/charger is plugged in or unplugged while the laptop is on)
hope this help a little, ask me if you need more assisst.
regards
Apr 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
My Gateway laptop NV54,shuts off when i either unplug the power chord or plug it in. Then it turns back on. The battery charges alright and works. Do you know what is the problem?
I would suspect a bad connection on the motherboard since you say your battery is OK--I take it to mean that your computer runs when plugged in or on battery.
Try this:
Leave the charger plugged into the computer and unplug it from the wall. Then plug it back in. Do you have the same problem? If not, then it's the physical act of plugging the plug into the machine that is causing the problem and that would be causing some kind of contact problem on the motherboard.
Apr 01, 2010 | Gateway Computers & Internet
Power chord problem
(1) Does the machine work with the cord plugged, if so it is the battery or the charger circuit at fault
(2) If it does not work then there is either a break in the cable where it enters the plug which plugs into the back of the laptop or the power supply has failed
Aug 31, 2009 | Sony VAIO VGN-NR430E/S NoteBook
My 3200 will only run when plugged into charger, won't charge bat
Try dusting the connector pins on your laptop and connecting the battery back.
Jun 24, 2009 | Averatec 3200 Notebook
Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
Jun 10, 2008 | IBM ThinkPad T43 Notebook
ASUS Eee PC 1000H Laptop Logo
135 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
