What does it mean when airconditioner leaks water in the house down the wall
    Sergeant:
  • 259 Answers
Make sure it is angled slightly toward the outside so the condensation which comes from the evaporator leaks outside.
Posted on Mar 15, 2011
Varnish from wall clock leaked onto walls inside house painted with flat water paint
Are you sure you mean leaked, please? Varnish can only leak when it's wet... in which case you should be able to wipe it off.
Nov 06, 2017 | Tools & Hardware - Others
Airconditioner leaking on drivers side
it may not be leaking it may be that the rubber hose that allows the heater case to drain is plugged up it is usually near the passenger side exhaust manifold and looks like a small rubber hose with a bend in it coming out f the fire wall and not connected to anything on the end sticking out.
Sep 23, 2012 | 2004 Mitsubishi Endeavor
Leaking water from airconditioner
evaporator drain is stopped up blow it out.
Apr 25, 2012 | Heating & Cooling
Water dripping from airconditioner inside the house
Water leak is the common issue in split a/cs. Due to coil,air filter, drain pan dust blocked, less rpm of blower motor, short of gas.
If service for the unit is more than 4 months, please do it first. And then check rpm of blower motor, if less replace capacitor.
Check gas pressure. Must be 60 PSI @ 98*F, of ambient temp. If less than that find leak and arrest and do gas charging. Thanks.
Jan 28, 2011 | Fujitsu 24C1 Air Conditioner
My weathermaster airconditioner is leaking water inside the house
either your unit is tiped inside too much or it may need to be cleaned. you need to remove it and take the shell off and spray it down with a hose to make sure the drain hole is clean. good luck!
ERIC
Jan 26, 2010 | Carrier Heating & Cooling
Why does my airconditioner leak
If this is a window ac then you need the back of the ac lower than the front, so the water can drain to the back.
Aug 18, 2009 | GE AZ28E15DAB Thru-Wall/Window Air...
My window air conditioner keeps freezing and leaking water does this mean i need a new part for it? the model number is FAA060P7A5
It is normal for airconditioner to have condensation. Just make sure the water don't go in the house. LOL
Aug 15, 2009 | Heating & Cooling
Hi my split airconditioner is leaking water inside the house
YOU DRAIN IS STOPPED UP, FIND WHERE YOUR WATER DRAINS OUT AND CHECK THE END AND SEE IF IT IS BLOCKED OR YOUR DRAINED IS STOPPED UP INSIDE WHERE THE COIL IS.
Jan 05, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Water leaking into the house - model AOT24RWGL
Either the drain line is clogged, or there is a hole in the pan.
Get a powerfull wet/dry shop vacume.
Attatch it to the end of the drain pipe and seal it tight and pull out any dirt, mold crud blockages.
Take the panel off so you can access the drain pan under the evap coil. Clean that out as well with the vac.
Once its nice and clean, poor a gallon or so of water into the pan bein g carefull to not pour to fast.
Make sure that the line is drainign well and look for any spots where there may be a crack, hole etc in the drain pan where water may leak out
Jan 01, 2009 | Fujitsu 24R1 Air Conditioner
Kenmore aircondition
First is to make sure the evap and condenser coils are very clean. A dirty evap coil will cause icing as well as a blower not running and low freon. Hope this helps. Thx RepairUSA
Aug 31, 2007 | Kenmore 75050 Wall/Window Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
