Need for replacement - Computers & Internet
  • 902 Answers
Please eleborate
Posted on Mar 15, 2011
What does the check engine light mean
Autozone says the top five reasons you get a check engine light comes on is:
O2 sensor needs replacing
Gas cap is loose, damaged, or needs replaced
Catalytic converter needs replaced
Mass air flow sensor needs cleaned or replaced
The spark plug or spark plug wires need replaced.
However, it is important to note that some Miatas may have a problem where the problem is caused by an improperly tightened fuel cap. However, due to improperly manufactured threads on the fuel filler pipe, the filler pipe may need to be replaced.
May 25, 2014 | 2002 Mazda Miata
Konica minolta bizhub 3010 cof 32
When was the last time the developer and drum where replaced? Does the machine say "REPLACE DRUM in the upper left corner of the operation screen? More then likely your drum and developer need to be replace if not those then the DEVELOPER CARTRIDGE NEED TO BE REPLACE when was the last time that was replaced? Every four drums the developer cartridge needs to be replaced. When the developer was replace was a F8 run from service mode?
May 16, 2014 | Minolta Office Equipment & Supplies
I need a replacement pump with lights for lion head fountain
need replacement lights for ion head fountain.
can't replace bulb. Rubber is brittle and broken.
need complete bulb and wire to transformer connection.
where do I order?
Jun 18, 2012 | Garden
On a 2003 hummer h3, if the outer cv boot is damaged, do both inner and outer need to be replaced?
  • Boots only need replaced when they have been negated and are leaking grease. However, the time effort and money to replace just one boot when the other is right there might bite you if the other boot needs replaced in the near future. However, if upon inspection the boot is not torn, worn and the knuckle still performs well you do not need to replace that boot.
  • Hope this helps.
Nov 17, 2011 | Cars & Trucks
I need step by step instruction on how to replace the condeser in my 2002 Pontiac Aztek. I heard that I will need to replace the dryer unit also and that I will need a certain type of oil to go into t
this is a professsional job to evacuate, add oil and recharge the a/c system. You couls change the condensor yourself and take it somewhere to recharge the system. You DO NOT need to replace the recevier/dryer either.
May 22, 2009 | 2002 Pontiac Aztek
Front rotor needs replacement
if you can't rock the caliper, the you don't need to change the bearing.
yes, we still pack grease. only way to go!
May 15, 2009 | 2001 Ford Expedition
O2 sensor bank 1, need to replace, I need a
ITS VERY EASY, DISCONNECT THE NEGATIVE BATTERY, UNPLUG THE O2 SENSOR WIRE PRESSING THE TAB AND USING A 22 mm. WRENCH LOOSE THE SENSOR LIKE A BOLT
Apr 12, 2009 | 2003 Toyota Corolla
2004 Nissan Quest front control arm bushing replacement.
Sorry guys not a solution but I too have an 04 Quest, which supposedly has worn controller arm bushings and Nissan says I need both controller arms replaced. For a total of $950!!! I was told that they need to replace the whole arm and cannot replace only the bushings. Now reading the posts on this site I find that to be untrue. Seems all I need to spend is anywhere from $25 to $35 per bushing.
Nov 30, 2008 | 2004 Nissan Quest
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
