If you changed automatic-file opener to something, can you restore the default?
  • 922 Answers
Yes, right click on one of the files that is opening with the wrong program and select Properties.
On the General tab in the Type of file section select Change.
Select the program you want to use to open the file from the recommendations or browse to the one you need.
Please vote for my solution if it helps.
Posted on Mar 15, 2011
Reset to factory defaults
go to windows help & type restore to factory defaults; here is what I found.
Restore system files and settings
System Restore helps you restore your computer's system files to an earlier point in time. Typically, you want to restore your computer to a restore point that was created just before the date and time when you started noticing problems. The descriptions of the restore points that are created automatically correspond with the name of an event, such as Windows Update installing an update. System Restore returns your computer to the state that it was in before the restore point that you choose. To learn more about how System Restore works, see What is System Restore?
To restore system files and settings using a recommended restore point
  1. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Click Recommended restore, and then click Next.
    If there isn't a recommended restore point, follow the steps below to choose a specific restore point.
  3. Review the restore point, and then click Finish.
To restore system files and settings using a specific restore point
  1. Do one of the following:
    • If there is a recommended restore point, click Choose a different restore point, and then click Next.
    • If there isn't a recommended restore point, click Next.
  2. Click the restore point that you want, and then click Next.
    To view the programs and drivers that will be affected (which could include programs that will be deleted), click Scan for affected programs.
  3. Review the resto
Mar 16, 2015 | Computers & Internet
Usb drive 0 bytes
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and readin windows 7
Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
You might have to alternate doing this repeatedly until the problem is resolved
Dec 04, 2013 | SanDisk 4GB microSDHC Memory Card
Repair usb flash drive
Which operating system ?????....
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
You might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
restore defaults
In XP
you might have to alternate doing this repeatedly until the problem is resolved
Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system.
if you need more help with this or if i have missed the problem post a reply
Oct 17, 2013 | Verbatim Computers & Internet
My preferred / default search engine is Google Chrome, but whilst searching for an online football game last night I inadvertently downloaded some software. This has now left me with "My Search Dial"...
Look in msconfig area for a startup file not previously there. Check it off. Ditto for item in services. msc file. Then type in the name of the file mysearch dial exactly as you see it in regedit and remove the sucker. Same for onlinegames. Hopefully you will get it like that. Also do a malwarebytes scan and get rid of all the junk it finds. That should do it.
Mar 31, 2017 | Computers & Internet
My sandisk backup 16gb usb will not open; every computer i put it in says to format, but i do not want to lose everything on it!!! first of all, can i fix it so i can recover my files? secondly, what did...
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 Click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 You might have to alternate doing this repeatedly until the problem is resolved Click start control panel scroll to folder options view place a tick in show hidden files folders and drives
If you need more help with this post a reply Hope this helps.
Jan 07, 2013 | SanDisk 16GB Ultra Backup USB 20 Flash...
Hi i can not delet any folder or file due option of delet is not showing in pen drive
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
restore defaults
In XP
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
hope this helps
Sep 16, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How can i set my default settings to memory card eg.everything that i downlowd or copy has to go to my memory card automatically
Hi lieselw...
You can restore all setting by restoring the phone to restore your phone Go to
Menu>Settings>Restore Factory Settings>OK(Default security code is 12345)>Yes(It takes 2-5Mins after restoration it starts automatically Don't switch off).
Actually a downloaded or copied file moves to memory card only if the Downloaded or copied file size excess than the Phone Memory.
or
sometimes if you activated Security code it won't takes any files to memory card.Delete the security code.
Thank you have a nice day
Jan 31, 2011 | Nokia 5230 Cell Phone
In windows 7 home basic if i open any application it will be open automatically open windows media player what is reason
It does that because Widows points all files at Windows programmes.
You can change it quite easily by clicking Start the selecting Default Programmes and moving things around to other programmes.
Keep a copy of the settings befor you adjust them by clicking Start and typing Restore Point, follow the prompts to make a restore point that you can go back to if you make a mistake.
Win 7 is the first almost clever OS to come out of Microsoft!
Hope that fixes your quandry.
Nov 27, 2010 | Microsoft Computers & Internet
I have DG31PR Original Motherboard with the system. I have installed Two HDD in the system Now i Want to change the boot order without entering BIOS Setup. Is it possible to press some function key like F7...
I assume you're wanting to automatically boot a different hard-drive? If so, it's a real simple fix. I'll take you through the steps using Windows XP Professional. In the example below we will tell the system to automatically boot Windows 7 if the user does not make a choice in 30 seconds.
1. Open My Computer.
2. Open your C:\ drive.
3. At the top, select Tools -> Folder Options (Picture)
4. Select "Show Hidden Files and Folders," Uncheck "Hide Extensions for known File Types," Uncheck "Hide Protected Operating System Files." (Picture)
5. Locate "boot.ini." (Picture)
6. Right-Click boot.ini and go to "Properties." (Picture)
7. Uncheck "Read-only" and press OK. (Picture)
8. Open boot.ini
9. Find the line corresponding with the system you want to boot automatically every time your system starts. (Picture)
10. Place the system's path into the "Default" slot. (Picture)
NOTE: Only place the system's path into the default slot, not the boot options and description!
11. Save the file and exit boot.ini.
12. Once again, right-click boot.ini and go to Properties. (Picture)
13. Check "Read-only" and press OK. (Picture)
14. Restart your system to ensure the changes were made correctly and that your system starts the correct operating system.
CAUTION: Altering the lines below "[operating systems]" can change the way you system starts and might prevent your system from starting! DO NOT ALTER ANY ENTRIES BELOW "[operating systems]" UNLESS YOU ABSOLUTELY KNOW WHAT YOU ARE DOING! Altering the "Default" slot will not harm your system as long as you enter a system path that is described in the "[operating system]" sector.
Altering boot.ini the way we just did tells the system to automatically start Windows 7 if the user does not make a choice in 30 seconds. Additionally, if you want the timer to run for say 1-3 seconds, you can alter the "timeout" value to read something similar to: timeout=2
That way when the system will automatically boot the "default" system in 2 seconds if the user doesn't make a choice. NOTE: Don't forget, you can't alter boot.ini unless "Read-only" is unchecked. Also, don't forget to check it again once you're finished editing boot.ini.
Let me know if this solved your problem, or if you were wondering how to do something else.
Jan 01, 2010 | Intel Computers & Internet
How do I undo a reformat on an HP? My HP was reformatted and I need to return it to the previous state. Already tried system restore, but prompt said there is no point to restore to. Is there a way to...
Troubleshooting
Accessing Computer Setup
The information and settings in Computer Setup are accessed
from the File, Security, Tools, and Advanced menus.
1. Open Computer Setup by turning on or restarting the
computer. Press f10 while the F10 = Based Setup message is
displayed in the lower-left corner of the screen.
To change the language, press f2.
To view navigation information, press f1.
To return to the Computer Setup menu, press esc.
2. Select the File, Security, Tools, or Advanced menu.
3. To exit Computer Setup, choose one of the following:
To exit without saving any changes, use the arrow keys to
select File > Ignore changes and exit, and then follow
the instructions on the screen.
To exit and save all the settings you have entered, use the
arrow keys to select File > Save changes and exit, and
then follow the instructions on the screen.
Your preferences are set when you exit Computer Setup and take
effect when the computer restarts.
Computer Setup Defaults
To return all settings in Computer Setup to the values that were
set at the factory:
2. Use the arrow keys to select File > Restore defaults.
3. Select the Restore Defaults check box.
2–2
Maintenance and Service Guide
Troubleshooting
4. To confirm the restoration, press f10.
5. Select File > Save changes and exit, and then follow the
When the computer restarts, the factory settings are restored, and
any identification information you have entered is saved.
Selecting from the File Menu
Table 2-1
File Menu
Select
To Do This
System Information ¦
View identification information about the
computer and any battery packs in the system.
View specification information about the
processor, memory and cache size, video
revision, keyboard controller version, and
system ROM.
Save to floppy Save system configuration settings to a diskette.
Restore to floppy Restore system configuration settings from a
diskette.
Restore defaults Replace configuration settings in Computer Setup
with factory default settings. (Identification
information is retained.)
Ignore changes and exit Cancel changes entered during the current
session. Then exit and restart the computer.
Save changes and exit Save changes entered during the current session.
Then exit and restart the computer. The changes
you save are in effect when the computer restarts.
2–3
Troubleshooting
Selecting from the Security Menu
Table 2-2
Security Menu
Select To Do This
Administrator password Enter, change, or delete an HP Administrator
password.
Power-on password Enter, change, or delete a power-on password.
Password options ¦
Enable/Disable stringent security.
Enable/Disable required password on restart.
DriveLock passwords Enable/disable DriveLock; change a DriveLock
user or master password.
DriveLock Settings are accessible only
when you enter Computer Setup by turning
on (not restarting) the computer.
Smart Card Security Enable/disable power-on support for smart cards.
This feature is supported by select smart
card readers only.
Embedded Security ¦
Enable/Disable the embedded security chip.
Restore embedded security chip to factory
settings.
Enable/Disable power-on authentication
support.
Enable/Disable automatic DriveLock.
Reset power-on authentication credential.
Embedded Security settings are accessible
only if the computer is equipped with an
Device security Enable/Disable devices in the system.
Enable NIC for inclusion in MultiBoot.
System IDs Enter user-defined identification values.
2–4 Maintenance and Service Guide
Troubleshooting
Selecting from the Tools Menu
Table 2-3
Tools Menu
Select To Do This
HDD Self Test options Run a quick or comprehensive self-test on any
hard drive in the system.
Battery Information View information about any battery packs in the
computer.
Jan 01, 2010 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
