I have a Jantitrol GMP 100-3. When it works, an exhaust fan kicks in for a minute, then the flames go on and it starts to heat. Then what started to happen was the exhaust fan would go on for a bit, go off, then go on, go off, then finally turn on, and then the furnace would light. Now it won't turn on at all. There is a significant dust source next to the furnace. Any advice? Thanks.
    Brigadier General:
  • 4,736 Answers
"There is a significant dust source next to the furnace." You were headed in the right direction without knowing. Dust can certainly play a big role in creating the problem. When the furnace is operating it's sucking in the surrounding dust and lint. This can clog the electrical contacts, cause false readings to the control panel and other damage. If you feel comfortable doing it, you can clean it yourself. Just remember to turn OFF all power to the furnace, before removing the panels and working inside the furnace. A Shop Vac with a hose, brush attachment and crevice tool will be a big help in cleaning. If you don't feel comfortable making it a DIY project, call a qualified technician to perform the work.
Hope this helped you.
Posted on Mar 16, 2011
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
Goodman GMP 100-5 Rev B Serial # 9902602550 The status light stays illuminated. It isn't blinking. I believe my igniter went bad. When I turn on my heat on the system, The exhaust fan kicks on,...
Hello, the first thing is check the igniter for any crack or white spots on it, also, if you have a multimeter check the resistance of the igniter, should be between 40-90 ohms. You can purchase a igniter at any Heating and Cooling supply store.
Mar 11, 2011 | Goodman GMS90703BXA Heater
Model 21 ,start monitor and the fan starts and orange lights come on ,then the lights bounce to 100 % and then back to half and then back to 100% real quick and the fan qiuts and heater never gets the...
This sounds like it is going to be a circuit board issue. When you turn it on the blower should start and the igniter will begin preheating the burner. After 3 minutes the burn lights should come on and you should begin to see some flame with a few seconds. The heater should burn on low for about 10 minutes to allow it to become evenly heated before going to high.
Dec 10, 2010 | Heating & Cooling
I have a honeywell gas heater hanging from the ceiling in my shop Model # uhpa175ae-3 Serial # 6396j03508 The exhaust fan starts, the flame lights and finally the main fan kicks in. Quite often, as soon...
HI clean the flame sensor check out the pressure switch jump this out to see if it lights clean sensor on fan control might be dirty clean heater with air line burners heat exchanger then it might be your limit switch but this help doing this other work first
Feb 01, 2010 | Heating & Cooling
Weatherking furnace is starting and stopping
This just sounds like a couple of problems. First, your blower is designed to only turn on once the heat exchanger heats up, so the flame will be on for a minute or two before the blower starts. it sounds like your blower is cooling down the heat exchanger too fast and causing it to shut off so it can warm up again...check blower speed for heat, it should be the lowest speed (black wire). Blue=medium speed, red= high speed. second problem could be your flame sensor rod is calcified, you just need to locate this and clean it off with some fine sand paper.it is located in the flames near the burners. Also change your filters, for proper air flow through your heat exchanger.
Oct 28, 2009 | Heating & Cooling
When I start my heater it ignites but goes right back out in about 2 - 5 seconds what is wrong withn it
First of all, when you start the pool heater the first thing that it does (I am talking about Jandy) is to start the Exhaust Fan to evacuate all the fumes...Is this happening????
After it does that, then the igniter glows and usually takes 17 sec before it reaches the temp.... Can you see it glowing through the eye glass???
When it reaches the temp, the Fan start in a low speed, then the gas valve open and is when the Natural Gas or Propane goes into the burners creating Flames.... If this happening???
Then, the flames are sensed by a "Flame Sensor" which if for any reason it does not sensed will shut down the pool heater... have you check the Flame Sensor????
Well, lets say the Flame sensor is fine and the gas ignites and you have a perfect combustion, so after a minute or two the Exhaust Fan is going to work in a high speed to evacuate heat and Fumes, but also it will shut down the heater if it can't kick on giving you an "Air Flow" message in your screen.
Check this and see if that gives you some ideas how to find the problem. If it does not work, I recommend to call the manufacture of the equipment an talk to then directly.
Feb 27, 2009 | Pool & Spa
My 90 + goodman starts up then when blower starts the flames go out i can hear a clicking in the bottom of the unit and the exhaust fan shuts off then i can hear it kick on and the furnace trys to start up...
if you get a flame for about 2-3 seconds, than is goes right out, it would be a flame sensor, get some fine sand paper and clean it reinstall and should work fine, the flame sensor would be on the left hand side normally on goodman , looks like a stright rod with only 1 wire going to it, normally a white wire.
Jan 02, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
