Question about Belkin (F5D5231-4) Router
I have a wireless printer and it won't connect. I tried text sopport for the printer and was told that the router needs to be insinck to the mac address . I would like to know if you could tell me how to do it . IT is belkin N, I am trying to connect it to a laptop. Thanks in advance
    Scholar:
  • 62 Answers
Setting up wireless printers can be such a hassle!
The quickest solution is to let the router sync the mac address itself, don't worry about the details of it all. Easiest way is to start wired, before you go wireless.
When setting up the printer to work with that wireless router, hook your printer up directly to the router/computer the router is connected to. This will allow for the printer/router to recognize each other and establish a connection. Then, when you use a wireless connection (wireless on laptop/ on printer also), they will recognize each other and you'll be able to connect.
This is much less of a hassle than trying to set up wirelessly.
Best of luck!
Posted on Mar 15, 2011
HP DESKJET D1360 HOW TO SET UP WIRELESSLY USING MAC
Are you trying to use MAC filtering. You would just need the MAC from the network setup screen and add it to your router/firewall.
If you are using a Mac (Apple) computer you would, providing you have a wireless adapter connected to Mac, just go into "System Preferences" and use the wizard under "Print & Scan". Make sure the networking on the printer is in on the same as your Mac.
Apr 15, 2014 | NetGear WGR614 Wireless Router
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
Connect network wireless
If you are using this as ethernet adapter, there definitely are IP addresses for each cable plugged into the router. Your MAC needs an IP address for the router to ROUTE the traffic to and from the internet. That's what Routers DO. Listen to your Support. Unplug all other devices from the router you connect to, then connect your adapter, and let the router assign an IP address to it. Then connect the rest of the devices one at a time, and see if that works. Make sure you plug the cable from the efibre to port #1 on the router, for highest priority of traffic.
Sep 13, 2013 | EMC LightPulse LP11000-E Fibre Channel...
Can not find printer on wireless network
I am pretty sure the HP J4680 is wireless only, at least I can't find any Ethernet ports on HP Officejet J4680 that are obvious. So first make sure the blue antennae light is on on the left side of the HP panel. If it is not on press the button that says 802.11g and the blue light will light up indicating that the wireless is now enabled. Check now and see if you can see the printer on the network. Power cycle the printer and router and then see if the printer shows up. If you think it is now connected you can go to step 9) below. if not go to the next step
If the above didn't work try and change the wireless settings from the front panel of the HP Officejet J4680. Press the setup button (the wrench) on the front panel, then scroll till you see Wireless Menu and press OK, then scroll till you see Setup Wizard and press OK. The printer will search for all the wireless routers it can find. It should display your wireless router SSID, this is the name of the router. When it shows you the name of the router press OK and it will display WPA Passphrase or WEP passphrase (depends on the security you have on your wireless router). If you see the SSID of your router this is a good thing, because it indicates that the wireless is working and just needs to be configured. Now type in the passphrase exactly (the same passphrase you use to connect your PC or Mac to the wireless internet) and press OK. It should connect to the wireless router. If this doesn't work, unplug and plug in the wireless router and the printer and try it again. If you think it is now connected to the wireless, then go to step 9) below. If the above doesn't work you can keep trying it but I haven't had much luck with the front panel method.
If the above fails to work, the next method to try is to connect a PC or Mac directly to the HP Officejet using the AD-HOC wireless method. I can't figure out how to get the HP printer into this AD-HOC mode unless I do a wireless reset of the values in the printer. There is prob a way to do this without a reset, but I couldn't get it. I would recommend you read through all the steps below before you do this. It will wipe out what you currently have setup in your printer. But these are the steps I just went through and I got my printer to connect to my MAC and work.
1) You might not have to do this step, but if all else fails reset the HP Officejet J4680 network by pressing the setup button (the wrench) go to Wireless Menu and Press OK then go to Reset Wireless select YES and press OK. If that doesn't work then there is another reset that I found in the setup menu (the wrench) under Tools and then Restore Defaults. I wound up doing both resets on my Officejet J4680
2) Power the HP Officejet off and on for good luck (again optional but might help).
3) Make sure the the wireless on the printer is enabled by pushing the button on the left side front under the 802.11g so that the blue wireless light turns on. (again optional, but make sure the blue antennae light is on)
4) Connect to the HP Officejet J4680 wireless printer directly from the MAC (this is pretty neat stuff) click on the Airport icon at the top bar of your mac screen, if you see the hpsetup listed then click on it, if it is not listed then click on join other network and type in hpsetup and click Join. This will join the mac to the Ad Hoc HPSetup network and you can now setup the printer from the mac!
5) Important: Print a network settings report on the HP Officejet by pressing the setup button again (the wrench) go to Print Report and press OK, go to Network config and press OK. If you try and print this before you connect (step 4) you will not get the info you need in the report, so connect first from Mac to HP then print this report.
6) fire up safari or Firefox or chrome browser on the Mac and type in the URL that is listed on the report you just printed out. It starts with http:// type in the http:// and the 4 numbers all together with no spaces into the address bar in your browser and press return.
7) you are now connected to the HP Officejet J4680 via the web browser interface. Click on Networking, then Advanced, click the infrastructure tab, type in the SSID of the wireless router (i.e. the name of the router you see when you try and wirelessly connect from a computer) and fill in the passphrase info for your router, type it again to confirm, then click apply.
8) The printer will change the connection from the Ad-Hoc network to the SSID of the wireless router. So you have to connect to the wireless printer, to do this on a MAC, you go to the top row of the mac and click the Airport icon, select the wireless router.
9) Now go to the spotlight icon (far right top row on the mac) type Print and then click on Print & FAX, if your printer is not listed, then click the + and add it. You should be able to check the supply levels on the HP, if you see the current time below the supply levels you are successfully connected. On a Windows system, you would go to control panel, then Printers and add your printer if it is not listed.
Also, below is a good video with even more detailed info:
10) Officejet J4680 setup via the mac using this very thorough guide: http://www.youtube.com/watch?v=Rjd1ZqJ89N4
edh 1-13-2011
Jan 07, 2011 | HP J4680 Office Jet All-In-One Printer
I have a Netgear WNR 2000 router for my home network. I am trying to connect an Epson NX420 printer. Instruction state to enter MAC address to router. I have the MAC address, but do not know how to enter...
I am not too familiar with NetGear routers, but all linksys routers have mac address filters, this allows the router to only accept connections from previously stated mac addresses. I never had to do such a thing for my wireless printer, but this could be the problem. Usually wireless printers just ask for a security code (WEP/etc.) and connect on their own. Sorry i cant be anymore direct.
Oct 02, 2010 | NetGear WGR614 Wireless Router
Hey, i recently got a Mac and tried to connect my Z1420 wireless Lexmark printer to it. The wireless did not work, but when i connected it via USB the printer worked. I settled for this but recently the...
You stated you have a mac. Is your Mac a laptop that provides wireless? Or are you on a Mac desk top connected to a router that has wireless included with it.. If you have either than you need to go into your network and sharing to set-up the wireless printer. This will give you access to your router via desktop or your wireless settings via laptop,
Once there if you are already using wireless settings you are going to have to allow your printer in through your wep or wap encryption settings. This was set up when you first started using your wireless to keep out intruders.
Mar 08, 2010 | Lexmark Z1420 InkJet Photo Printer
Wireless connection problem. Computer does not recognize router
if you are not able to connect wirelessly it is possible that the mac address filter is enabled in the router / check this page for help.
http://www.belkin.com/support/article/?lid=en&pid=f5d7230-4&aid=1488&scid=0
Jul 16, 2009 | Belkin (F5D5231-4) Router
Brother printer and Neygear router wireless connection bad.
Had the same issue. Change the router wireless security settings from TKIP to AES algorithms. This did the trick for me.
Feb 21, 2009 | Brother MultiFunction Center MFC-440CN...
Wirless Printer won"t network with the router
Check your wireless security settings and make sure the mac address of your printer is allowed to connect to the router. In addition, I would set my printer to only allow incoming connections from the router or you will have people driving by, printing ads that you probably will not like.
Dec 29, 2008 | HP Office Equipment & Supplies
Belkin (F5D5231-4) Router Logo
129 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
