The TNS on are Kia made a noise while it was shut off, and when we turned the car on the noise stoped. We tried to start the car but the car was Dead. So wha is the TNS and if we get it replaced will the car start and not make that noise?
csmock132
  • 4669 Answers
SOURCE: engine turns wont start
Do a compression check. You might have bent the valves.
Posted on May 04, 2009
roniecon
  • 6927 Answers
SOURCE: lights work inside and out, when i try to start my
Remove the battery cables and clean them,and the battery post.Make them shine,or it will be the same problem again.Make sure the battery cable ends are shiney and clean,and the battery post.This is most likely the problem.Let us know if this is helpful,thank you.
Posted on Oct 09, 2009
  • 177 Answers
SOURCE: kia sedona 2002 headligth dont turn on
Have you checked the wirings?Are they ok?
Toyota Performance Chips
Posted on Aug 12, 2012
rustfarmer
  • 5324 Answers
SOURCE: When I open the driver door the car starts honking and the tns relay starts ticking and the car will not turn over how can i fix this problem?
Reset security system. On some cars, insert key, turn to "on" without trying to start and wait 10 or 15 minutes. Turn key off, then try to start car. If this doesn't work, you might try telling us what you are working on.
Posted on Mar 01, 2016
Mar 01, 2016 | Cars & Trucks
A TNS fuse is clicking when the ignition switch is off but when i go to ACC the clicking stops. What does this fuse do and what does it stand for and 3 what can I do to get this fixed
It is not a fuse, it is a relay.
  • TNS controls parking lights, tail lights and running lights.
  • Not sure what TNS stands for but my guess would be "Taillight, Night Running lights and Stop light"
  • Normally the TNS relay is powered by the taillight fuse and is energized when the headlight switch is turned on
Having said that I'm not sure why it would be cycling when the ignition switch is off. Could be a short to ground somewhere in the system. If you have had any work done I would have it rechecked, especially if you swapped out radios or added extra lighting somewhere.
Other things you can try:
  • Pull the taillight fuse. The TNS should not have power and the lights will not work.
  • If the TNS is a removable type of relay pull it out and see if you still hear something clicking
  • With the relay pulled check the base. The coil side should have 12vdc to ground on one side. the other side should not have continuity to ground with the headlight switch off.
  • If there are other relays in the box of the same type, try swapping them out and see fir the problem follows the relay.
While these things will not fix the problem it may help diagnose the underlying problem.
Oct 28, 2015 | 2001 Mazda MPV
How to cure a ticking relay in tns slot on kia rio.
If its a sealed relay, tap on it, or you may need to unplug and replace it.
Oct 19, 2015 | 2003 Kia Rio
Tns relay is making nosie on my 98 kia sephia
Check and replace if it is not working properly all mechanical relays will make noise when they click once to engage current to the load side of the circuit.
Oct 19, 2014 | 1998 Kia Sephia
My 2000 kia rio keeps blowing the fuse for the rear right light and also the TNS fuse i have no dash lights someone help me please :(
You need special training to find these kinds of electrical problems, there is no magic bullet to fix it, the shorted component is different almost every time. Seek professional assistance.
Aug 24, 2012 | 2001 Kia Rio
Hello, I have a 2002 Kia Rio 4 dr. When you turn on the light switch for the lights to come on..the switch is supposed to turn on the headlights, taillights and light on the dashboard. Now the swtich...
Check for power at the left and right tail lamp fuses in the fueblock. If there is no power check the TNS fuse. If there is power there than you can try swapping the TNS relay with another relay in the fuseblock that is the same. If there is still no power after swapping the TNS relay you need to check the light switch.
You need to check the green wire on pin two on the back of the light switch to see if there is power there. If there is power than the light switch is probably bad.
You could also check the light switch operation with the TNS relay removed. Two of the pins in the fuse block should have power to them. One should be grounded all the time (the one that feeds power to the fuses) and one should be grounded only when the light switch is on.
Since the instrument cluster illumination gets its power from the right taillight fuse it has to be one of the above.
Apr 20, 2011 | Kia Rio Cars & Trucks
The rear driving lights do not turn on. bulbs are good. can't find a blown fuse or any even figure out which fuse these lights are on
check the 10 amp fuse labeled "EXT". also try swapping the "TNS" relay with the horn relay. These are probably in the engine compartment relay box. Let me know if you have questions.
Nov 06, 2010 | 2002 Kia Sedona
24 people viewed this question
 Grubhead
Grubhead
