Question about Sony RDR-VX535 Player
My SONY RDR-VX535 is stuck in DVD Mode 1. I tried pressing "ENTER" and "1" on the RMT-D255A remote for over 3 seconds. I did this several times in a different room away from the RDR-VX535, but it doesn't work. Any suggestion? Thanks, J
2 Suggested Answers
  • 4 Answers
SOURCE: can't get my sony RDR- VX535 out of the 2 mode.
*Take the remote away from the player. Then hold the enter button and the code* 1 or 2 down for 3 sec. and then you will get some use and you can reset factory defaults. Then repeat from * to * reset for code 3. Hope this works for you.
Posted on Aug 03, 2009
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Jan 02, 2011 | Sony RDR-VX535 Player
SONY RMT-D240A NO LONGER WORKS, IS THERE AN INEXPENSIVE REPLACEMENT?
my solution was to press enter and 1 simultaneously for 5 seconds, then press menue/system. I reset the date, and my remote worked as before. Caused by changing batteries after the remote was in storage for a year.
Aug 22, 2010 | Sony RDR-VX555
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Accidentally reset from DVD3 to DVD1...Now nothing will work including the remote control...Is there a process to change it back?
Press & hold the Enter button. Then press & hold the number 1 for a few seconds. Release both. Now, press the System Menu button. You should have access to the system menu.
Aug 25, 2009 | Sony RDR-VX535 Player
Can't get my sony RDR- VX535 out of the 2 mode. remote will not operate the recorder. i perchased this unit used on ebay. it played fine until i got it out of wack the remote with this unit is a sony...
Jul 28, 2009 | Sony RDR-VX535 Player
I have Sony RDR-VX535 and suddenly every time I press the remote it reads DVD 3 and does not perform any of the functions that I requested.
Your DVD recorder is set on DVD-3 remote option, check DVD Recorder remote lower section for DVD Mode button that has 3 options, set it on DVD-3 and recorder will start responding on your commands of remote.
Jul 10, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Matching remote to Sony RDRVX560??
set the remote comander for code imput mode press set and menu when the set light are on enter the code number then press enter before you enter the code num press dvd or vcr then press enter sony
Mar 14, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
Remote is Stuck in DVD 1 mode
I had this same problem (DVD1). Resolved as follows: With DVD player on, pointed remote at DVD player, pressed and held the 1 key and then pressed and held the enter key (both at same time) until I saw the DVD1 on the DVD player display disappear. Now everything works.
Jun 23, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Sony RDR-VX535 Player Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
