Question about GE Blenders
GE single serve blender 898679--need replacement plastic gasket for grinding jar. I am told by Walmart, where I purchased it, that I need to return it. I don't want to return it. The blade chewed up the seal so this will likely happen again; I need to find replacement seals.
I had the same issue. i took the gasket from the other blade to use with the blade i use everyday. one trick is, don't remove that gasket to clean it but make sure it stays in there. Just soak it and scrub it good, to make sure it stays seated in there.
If the gasket comes loose while you are grinding, the lid will come loose in the base and sometimes causes you to not be able to get the jar from the base. you have to turn the jar the opposite direction to get the lid to tighten up, then you can remove the jar from the base.
I am trying to get replacement jars since those plastic nobbies that run the blender have broken off. It is down to one of 3 nobbies, so it can't be run anymore. I mght just have to buy a brand new blender but it seems so wasteful.
Posted on Jan 28, 2012
  • Analyzaah Oct 21, 2012
    Not taking it out to clean is unsanitary! I used to work for a restaurant and they had similar bands we called "O" rings, we used a lubricant similar to the same thing as petroleum jelly and I found lubricanting my bands with this product actually work plus making sure the band is flat side to the bottom of the base for the blender! Hope this help!
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
  • 6 Answers
SOURCE: I have a K-TEC HP3
Usualy there is a rubber ring araound the bottom of the blade. If it gets worn out or out of posistion it may start to leak. Also if you dont have everything screwed in tight enought it could leak as well
Posted on Jan 03, 2009
SOURCE: Jar blender blade bottom screw on piece
villaware 1-866-484-5529
Posted on Nov 20, 2007
  • 38 Answers
SOURCE: Blades on inside of kitchenaid blender jar won't turn.
look on ebay for a replacement second hand unit
Posted on Nov 09, 2009
SOURCE: the jar of the ge
Most likely the problem is caused because the base is not screwed all the way on to the jar. This could be from just not turning it on all the way or it could loosen while running. Make sure the base is tightly closed before putting is into the power unit. To remove it you can lubricate the tabs with some vegetable oil and then force it. GE service suggested that. I have heard of two people joining forces to get it off without apparently damaging it but no guaranty's. If you have the reciept it should have a two year warranty, at least mine does.
Posted on Dec 27, 2010
Need replacement jar for model #14074 purchased 2003
If it cannot be purchased right from the maufacturer (which it likely won't as it is 11 years old), you can get nice blenders for around $20 at super stores like Walmart that work well and last for a while.
Jul 08, 2014 | Ultrex 834-334 Die Cast Work Top Blender
Ksb555
If you have the glass jar then purchase either a new rubber seal for the blade to jar fitment or replace the blade assembly, it will be one or the other. If you have plastic beaker then get a new beaker, it is sold as a single assembly.
Nov 29, 2013 | KitchenAid Blenders
G E single serve blender 898695-- need replacement parts
sure, amazon is best place for searching parts... take a look Healthy Blend of Power Precision and Value. enjoy
Jan 19, 2013 | GE Blenders
The jar of the ge single serve blender got struck. How to fix it
Dec 01, 2010 | GE Blenders
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Unit began smoking and smelled hot
If this was a recent purchase for which you have a receipt, return it to the store immediately while you still can. If it is beyond the store's return policy, but purchased less than one year ago (most times you will still need a receipt), call Black and Decker to get in-warranty service/replacement.
In fact, call Black and Decker anyways - if the BL5000 was manufactured between Dec.2003 and Jan.2005 (highly possible if it was marked on clearance), the blade assemblies were recalled. here is the recall notice:
http://www.blackanddeckerappliances.net/safetyrecall2.html
If it is out of warranty, let the blender cool for an hour. Then remove the blender jar, plug in the base, and see if it will spin with nothing attached to it. See if it smokes if left on for 1 full minute - don't let it run longer than one minute.
If it doesn't smoke, let it cool for an additional 20 minutes. Then remove and then reassemble the blade assembly, gasket, etc., collar, jar, etc. Try blending. If it smokes while blending, order a new blade assembly and gasket (usually they come packaged together - around $20 or so). Once the new blade assembly/gasket arrives, try blending again. If it doesn't smoke, you're probably good to go. If it does smoke, you have a more serious issue.
All of this is going to take time and money if it is out-of-warranty. If you have deemed that the blender is worth more than $50 for a new one, let me know.
Mar 26, 2009 | Black & Decker BL5000 ProBlend Work Top...
Replacement glass jug?
I will buy the blade set from you? I will return....
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Blenders Logo
2,726 people viewed this question
Top GE Blenders Experts
Tom Chichester
ray gallant
Are you a GE Blender Expert? Answer questions, earn points and help others
