Question about ASUS Intel 440BX Chipset P2B-S Motherboard
Memory question what is the difference in kvr100x64c2/256 and kvr100 256
  • marieblair19 Aug 03, 2008
    can you use the 2 different types together ?are they compatible?
    Problem Solver:
  • 10 Answers
Each memory contain chipset , with black block coloured, each of this chipset has the ability of error parity checking, and own their clock latency, KVR is the kingston chipset , 100 stand for the clock or memory clock, PC 100 is means that the memory is SDRAM, While the DDRAM stands for 266(PC 2100) , 333 (PC 2700) . and the other x64 means this memory support 64 bit data flows, cl2 means clock latency (the delay for the memory to write and read), and 256 is the real size of the memory module.
Posted on Aug 01, 2008
Discrepancy in Cell Phone Memory
Understanding RAM, SD Card and Device Memory of an ...
android.stackexchange.com/.../understanding-ram-sd-card-and-device-m...
Aug 19, 2014 - Device Memory is your phones built in memory, just like SD Card hasmemory ... as to the difference between SD memory and internal memory. .... Can I stop a fellow passenger from using their cell phone during take off?
Difference between "Device memory"... ' Samsung Galaxy S II I9100 ...
forum.xda-developers.com/.../difference-device-memory-usb-storage-t1...
Jul 13, 2012 - 5 posts - ‎4 authors
Difference between "Device memory" and "USB storage". ... Whats is the differencebetween device memory and USB storage? As far as i see all the apps installed on the Device memory and all the photos and other files are located on the USB storage.
Whats the Difference Between Flash Memory and SD ... - eBay
www.ebay.com > ... > Camera & Photo Accessories > Memory Cards
This guide will take a look at the differences between flash and SD memory, and ...from digital still cameras, video cameras/camcorders, tablets, to cell phones ...
android - Difference between INTERNAL SD CARD and ...
Jan 28, 2016 | Cell Phones
Can i use DDR2 SODIMM 800MHz PC6400 in my laptop even though the one in it now is a DDR SODIMM PC3200 CL3?
pc3200 is original ddr- ram but pc6400 specifies to ddr2. The ram is not compatible. And the key slots on your mainboard will prevent installation.
Aug 20, 2011 | Compaq Computers & Internet
Nokia N73 Cellular Phone not read memory card
1. try to reboot your cellphone first, if nothing happens, go to the next step.
2. try to remove your memory card for at least 15 second, then plug it back in, if nothing happens go to the next step.
3. Try to plug your memory card to a different cellphone, then if it works for the different cellphone then your phone has something to do with it, but then if the memory card will not work in different cellphone, then your memory card is defective.
if your memory card is still under the warranty, I know they can replace it for you.
Jun 12, 2011 | Nokia N73 Cellular Phone
When i try to format my memory stick, i get an error message that says "windows cannot complete format"
It sounds that it just needs a different form of formatting try selecting a different option NSTC or FAT
Jan 24, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
Memory card is not being accepted by phone
Is that a brand you memory card? First, try to insert the problem memory card in to a different phone and see if the same problem will occur. If the card gets recognized by other phone, then try to insert a different and known working memory card to the phone that you are having a problem with.
But if the memory card does not work on two different phones, then it's a bad card and you need to replace it.
Let me know if you have questions.
Thank you!
Sep 12, 2010 | Motorola Mobility Moto W233 Renew Cell...
Memory card slots
1 of 2 things.
1, The memory is not compatible.
or 2, the new memory is not the same as the existing memory. Most mother boards can take a few different types or speed memory. So the speed of the memory in the pc is different then whats in it.
it all has to match.
Jan 21, 2010 | Acer Aspire™ T180 PC Desktop
E71 memory card unreadable
please check it with another battery
May 03, 2009 | Nokia E71 Smartphone
Memory upgrade
We have the memory you need. Memory-Up is committed to provide the best memory and excellent services for all of our customers. We know that sometimes it is a bit confusing to buy the correct type, speed, and capacity of memory for your system. Therefore we hope that these tips below would help you for buying the new memory.
Memory Upgrade Tips
What is Compatibility and Memory Density Issue?
Memory module can be composed using different type of memory chips and therefore created different type of density for the module. For instance, a 512MB PC2700 DDR SODIMM memory can be composed using eight 32x16(High Density 512Mb technology) memory chips or sixteen 32x8(Low Density 256Mb technology) memory chips. As the laptops are equipped with different memory chipsets, some older laptop (chipset) would have compatibility issue working with the modules that is built with the newer 512Mb technology. Using the Not-Compatible memory will result the laptop to either not boot or only recognizing half of the memory modules. Thus that is not the correct memory for your system. Our Memory Finder and Memory Scanner will help to eliminate those problems and find the correct memory for you. We guaranteed the memory to work or your money back.
How much memory do I need?
Here are some general descriptions for different type of users and the amount of memory they would need for their systems.
Normal User: The system is mainly used for checking e-mails, processing word/excel file, and web surfing. Suggestion: 512MB to 1GB of system memory.
Power User: The system is mainly used for playing computer games, editing photos/videos, running database queries, or multi-tasking environment. (Surfing web/Processing Word/Excel File/Listening to Music). Suggestion: 1GB to 2GB of system memory.
Super User: The system is mainly used for running large number of database queries, professional editing of photos/videos, heavy multi-tasking environment. Usually a server or a workstation would be considered as Super User due to the multiple accesses from users. Suggestion: 2GB and above of system memory.
How much memory and memory slot do I have with my system?
You can download our Memory-Scanner to find out the the amount of memory that you have and the memory slots that are available for upgrade.
How many memory module should I buy?
It is recommended to purchase one module with bigger capacity than two modules with smaller capacity. For instance, if you can buy either one 1GB memory module or two 512MB memory modules for your system, it is recommended to get one 1GB and leave the other memory slot empty for future upgrade if necessary.
Note: For systems that supports dual channel memory mode, although memory modules need to be installed in pairs to enable Dual Channel Memory Mode, we still recommended users to purchase one bigger module than two smaller modules since Dual Channel Memory Mode has only a minimal improvement in the actual system performance.
What if I want to mix different memory together?
Different sizes/speeds of memory can be used together as long as their specification are qualified by the systems. For instance, a laptop can use one 256MB and one 1GB of memory for the total of 1.25GB system memory. Mixing two different speeds of memory modules would result the system to run at the speed of the slower memory between the two modules. We recommend users to use our Memory Finder or Memory Scanner to find the correct memory for your system.
i thnk that will helpfull for u
Oct 18, 2008 | HP Pavilion ZE5730 Notebook
Pda newbie - memory question
If you are referring to the difference between Compact Flash and Secure Digital memory, then there is no difference, except the format. By providing two different memory slots, you are able to install more memory, or use one slot for memory, while using the second slot for other peripherals, like network cards, modems, or wireless cards.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Difference between MPEG2 and MPEG4
To achieve MPEG2 video performance, large amounts of data must be written to the SD Memory Card in real time. The read and write speed of the SD Memory Card may differ from manufacturer to manufacturer, so we recommend using Panasonic SD Memory Cards with the high-speed transmission rate of 10MB per second (SD Memory Cards that are 256MB* or higher have a transmission rate of 10MB per second). * FINE Mode recording (High image quality 704 x 480 pixels) recording requires an SD Memory Card that is 256MB* or higher. * NORM Mode recording (Normal image quality 352 x 480 pixels) recording requires an SD Memory Card that is 32MB* or higher.
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
ASUS Intel 440BX Chipset P2B-S Motherboard Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
