Question about LG WM2688HWM TROMM SteamWasher
Wont drain the indicator says the hose or filter is clogged
  • 33 Answers
You can drain it manually with the little trap at the bottom of the washer and verify if there is anything in that trap. Make sure you have a bucket or something underneath because water will gush out.
Posted on Mar 15, 2011
Dishwasher stops working., all indicator lights go on and display shows OE
Hi
OE in your LG dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Daniel
Jun 07, 2011 | LG Dishwashers
Wont drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Daniel
Apr 17, 2011 | Whirlpool GU2800XTVS Builtin Dishwasher
Water wont drain
Hi
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Mar 18, 2011 | Dishwashers
It wont drain
Hi
Feb 20, 2011 | Dishwashers
My portable GE dishwasher is clogged and wont drain
Hi
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Wont pump out water
Hi
Daniel
Feb 09, 2011 | Kenmore Dishwashers
The water does not drain I check for clogged lines and they where not. could it be my drain plump si shot
You did not indicate that you pulled the pump filter to check for a clog or restriction. If you did not pull the filter out then I recommend that you follow the steps shown in this image to pull the pump filter out and check for a clog or restriction in this area. Since the tub drained using the hose beside this filter then it is likely that a clog or restriction in the pump filter is causing your drain problem. If you find no problems in this filter then you could have an undetected clog in the drain hose or you could have failed/clogged drain pump. If the pump is not running in the drain mode then you could have a failed control board or a wiring failure.
Jan 09, 2011 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Water wont drain from dishwasher
Hi
Daniel
Jan 01, 2011 | Dishwashers
Wont spin
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 25, 2010 | LG WM-2277HW Front Load Washer
Washing Machines Logo
204 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
