Question about Electrolux Central Vacuum
Vacumn loses power when on. goes on and off.
What must I check when this happens. I have emtied container and tried another outlet.
  • Anonymous May 20, 2009
    I have the same problem and there is a frowny face on the digital read out on the unit.  do you have that too?
  • 357 Answers
I think you need a new power cord. If you have a Kirby, here is a helpful link...
Posted on Aug 28, 2008
Vacumn cleaner does not start green light indicates power goes to the vacumn cleaner
the top part of the cage where the bag goes in has a tiny switch that goes down when the bag is in.Sometimes the cardboard top of the bag does not depress the switch.Check thast first.
Sep 13, 2014 | Electrolux hose 2100 series diplomat
Vacumn motor does not start with the switch. Light indicates the vacumn is on
check the top area of where the bag goes in.There is a tiny switch that get pushed down by the cardboard top of the bag.This is to protect the motor by not allowing the motor to engage without a bag
Sep 13, 2014 | Electrolux electric hose models 2100
How do I get hand held vacumn to work without attaching it?
Sounds like the dirt container if full and overflowing.
Aug 31, 2014 | Vacuums
When I insert the hose into an vacumn outlet nothing happens. I tried pressing the reset button but still nothing.
First, make sure the unit is still plugged in.
2. Ensure the circuit breaker has not blown. This is easily checked by simply plugging another item into the outlet. If it has blown, flip it back on. If it continues to blow, there's a short in the cord or wiring of the vacuum.
3. Is it just one outlet, or all of them. If it's just one, it needs replaced.
4. Check the prongs on the hose, wands, and power nozzle to ensure they haven't shorted out.
5. Use a multimeter or continuity tester to check wires in the hose. Touch lead of the mm or ct to a prong on the hose, the other lead to the connector on the other end of the hose. Check both connectors. One should show continuity, the other will not. Repeat for other prong. If either prong shows zero, hose needs replaced.
6. Motor is burned out and needs replaced.
There are other problems that could cause this, so I recommend taking it to the Broan-NuTone dealer you got it from for them to check the vacuum for problems.
Dec 19, 2010 | Broan-NuTone CV353 Central Vacuum
Not working  I hit the switch and there is no sound of a motor.  Nothing is happening.  It was working seconds earlier and suddenly it stopped.  The plug was in and I replugged it into...
If it was just a broken belt you would still hear the motor running. most likely its in your cord or switch. check the main cord, connections to the switch, and also the motor supply cord that goes from the handle to the vacuum head.
Feb 26, 2010 | Oreck XL Ultra Bagged Upright Vacuum
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
Power brush will only operate on push stroke
If the motor runs, the circuit breaker is working. If it only works on the push stroke, you probably have burnt contacts where the handle and/or wands and/or power head connect. When you push, the contacts are pressed together; when you pull, they are separated and the motor loses power. The only solution is to replace the connector parts.
May 06, 2009 | Vacuums
No vacumn action
Is the roller turning, if not you may need a new belt and/or brush roll. Did you check the inlet by the brush roll?
Feb 09, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Bissell Healthy Home Vacumn
On the Healthy Homes Vac, did you check the switch for the vac, there are 2 on the handle, and the one could be open. Check the wiring at the motor, could even be the motor itself. If at the motor there is a thermostat, it could be bad, but comes with the motor.
Jan 06, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
95 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
