Question about Mitsubishi CS-35505 35" TV
I have a Mitsubishi CS-35305 35 inch tv that has just a horizontal line across the middle of the tv. It has sound with no picture, just a horizontal line in the middle of the tv.
3 Suggested Answers
SOURCE: Mitsubishi CS-3515R tv problem
is locked and forgot my 4 digital code number
Posted on Sep 29, 2008
wyoed1
  • 211 Answers
SOURCE: Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Posted on Dec 19, 2008
Mitsubishi cs-27tx1. Only has a thin horizontal line thru middle of screen
Hello
Total Vertical Sweep failure had occured in your TV. That is there is only horizontal sweep there, and the whole picture sweeps horizontally and you see a horizontal nice line across the screen, at the middle of it. In this case, all other buttons will work, and sound output will be Ok.
This fault is normally due to Vertical Sweep Out Ic trouble. You have to open the back cover of your TV, and have to pull the main board out. Locate the Vertical Output Ic. It is easy to locate it. There will be four wires going to the deflection yoke assembly [the coil fitted alongwith the picture tubes' neck]. Amoung them, two will be thick, and is carrying horizontal sweep signals. The other two wire are comming from vertical sweep section. Follow the wires and find out from where it comes from the main board. Somewhere near it orginates from the main board, you will see an Ic usually screwed into a heat sink [ a metal plate or so]; and it is vertical output Ic.
Check first, whether there is input voltage [working voltage] come to it or not. Sometimes an open resistor problem may occur to show this fault. Normally vertical section will have a voltage rating between 18 to 35VDC. If that voltage is there, surely the Ic said above is damaged. Screw it out and desolder it from the mainboard, and go for an identical type and number, replacing it will solve your problem.
Take all precautions when we works with an elctrical equipment. Keep away children and never allow even stand beside you while you are working, and let an adult beside you as a precaution. Never use metal chair. Do wear a plastic of rubber shoes. If can, keep matted the floor also with carpet. Ok
Wish you success.
Gopakumar G.
Oct 25, 2010 | Mitsubishi CS-13104 TV
My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
May 14, 2009 | iLO IWT3206 TV
Magnavox 27 Inch TV- no picture but has sound
the vert. circuit need to be rebuilted
Aug 04, 2008 | Televison & Video
1993 tube 37" mitsubishi
It looks like the vertical amplifier IC401 is defective. If you have soldering/desoldering skills you can change this part yourself. Also you may have to change C471 (.01UF 50V).
Good Luck.
Feb 11, 2008 | Mitsubishi CS-35505 35" TV
TV problem
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Regards
Patrick
P-Tronics
Feb 03, 2008 | Mitsubishi CS-27205 TV
Jan 21, 2008 | Mitsubishi CS-35503 TV
Mitsubishi CS-27205 shrunken picture
Good set...worth repairing vertical circuit.....in shop...
about 100.00........................T.
Nov 15, 2007 | Mitsubishi CS-27205 TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
