Question about Thermos Gas Grill 4617222
How do I loosen a propane canister knob - Thermos Gas Grill 4617222
    Brigadier General:
  • 4,736 Answers
Are you asking about how to loosen the knob on the tank or how to remove the tank from the grill's holder?
If you're trying to turn the tank valve to ON, you turn the knob Counter Clockwise. If you trying to remove the On/Off knob itself, you remove the screw in the center of the knob. Most require a Star Head screw driver of bit to do this. Be sure the tank valve if completely OFF, before attempting this.
To remove the tank from the grill holder, simply lift the holder off the top rim of the tank. It may be snug, so it sill require some force.
Hope this helps you solve the problem.
Posted on Mar 15, 2011
Unable to light up my outdoor heater model#: HSS-DSSPC
Next time spend the 11.99 for the two-year extended replacement warranty
May 26, 2012 | Heating & Cooling
Mount propane tank
The tank has openings in the handle or frame around the valve. These openings should slip over a mounting bracket on the grill frame under the control knob platform. You may have to loosen a thumb screw to loosen a retaining piece that helps secure the tank on the mounting bracket.
Jul 19, 2011 | Weber Genesis Silver A Grill
Weber Q 120--propane leak when removing canister
i would say that might be faulty mine just screws together and unscrews nothing falls out
Apr 20, 2010 | Weber Baby Q Grill
Propane tank knob is stuck
same problem as other posted. If you turn on the propane bottle valve too quickly, it activates the safety valve and shuts it off until you get it turned on with a device your dealer (mine was Amerigas) puts his tool in it to reset it. DON't turn these valves open fast in the futuere. A nail inserted and a strike with hammer may fix it, but I recommend your gas dealer.
Sep 21, 2009 | Thermos Gas Grill 4617222
IGNITION WITH PROPANE DEEP FRYER
this is a safty feature turn and hold pilot light untill lite then the gas should flow..but only after pilot is lit for 30 seconds
Nov 27, 2008 | Kitchen Appliances - Others
Changing propane tank
Ok on the propane tank valve there will be a black assy. connected to the output side of the valve, if this is the black knob you are talking about it might be stuck if this is the case you might take a pair of slip joint pliers and try taking it loose that way looking at the knob from the front with the tank behind you it will turn counter clokwise to loosen it.
Hope this helps Ya
please rate me.
Jul 17, 2008 | Thermos Gas Grill 4617222
Gas grille won't light
I have a baby Weber grille. It can take a propane canister and/or use a regular size propane tank with the proper hose. In either case it doesn't appear that propane is getting through to the burner and as a result it won't light.
Apr 17, 2008 | Grilling
Thermos Gas Grill 4617222 Logo
303 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
