I need the wired network driver to HP mini 110-1050LA OS XP profecional.
  • 4,472 Answers
You can find the driver at this link:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-71205-1&lc=en&dlc=en&cc=us&os=228&product=3966064&sw_lang=
If you need any further assistance please let me know.
Thank you and enjoy,
Lee
Posted on Mar 15, 2011
Install windows xp on hp mini with an external DVD rom
This notebook will not run properly with XP as an OS. There are no drivers as XP was obsolete before this notebook was first made.
Jan 14, 2014 | HP Mini 210-1030NR Netbook
Using Bart PE with OS/xp can not find network drivers for optiplex 390
Forget Bart .. Try and google download hirens boot cd v15..it is the best allround fixer and has ALL the drivers and standalone fixes for all you need with built in mini Xp Os for startup from disc.
Feb 12, 2013 | Dell OptiPlex 390 DT Desktop Computer...
How to connect my hp pavilion 7915 desktop to a wifi network ?
The HP Pavilion 7915 will need a wifi network adapter card to connect to a wireless network. You would need to add an wired network interface adapter card to use a wired network, instead of a dial up connection. Check the height of your computer - a "Low Profile Card" may be needed. There are several versions of the 7915.
You can get a USB network adapter or a PCI slot card for either type of network from most computer stores. Depending on which version of the 7915 you have, you may have a limited number of USB ports. In that case the PCI card may be a better option assuming you have an available slot. Other models only have one PCI slot which can be blocked by a VGA card.
What OS is on your computer? I see some models shipped with XP and others with an older version of Windows. You will need to find a card that has drivers for your OS. Finding XP drivers will be easier than those for the older versions of Windows. Depending on the unit you order and your OS, the drivers may be already be installed in the OS. In that case, plug it in and go.
If you go with a PCI wireless network interface card, turn off the computer and unplug all of the wires before opening your case. Ground yourself relative to the computer by touching a metal part of the case before continuing. Remove the slot cover screw (hex head with a Philips slot) (for most desktops) from an available slot. Push the section of the card with the gold contacts fully into the slot. Work carefully and keep the slot section of the card between the case and motherboard. Press firmly and make sure that the card is level all the way across. Then screw the slot bracket down. (Note: you could remove the fax/modem instead of the cover if you do not need the modem.)
For a USB interface option, just plug it in. When the drivers are installed (follow the directions), attach the wifi antenna (if needed). Try to identify available networks (in XP click Start > Control Panel > Network then go to the network wizard to add a new network). Use the network ID and password for your wireless router. (I assume there are other wireless devices and the router has been set up; many older models need to be attached to a computer via a wired ethernet port for the initial set up. Most models have an initial name and password that should be changed.)
I hope this helps. If you have additional questions, please provide more information about your computer's OS and available expansion options. Also indicate what router you are using.
Oct 27, 2012 | Computers & Internet
Conputer: HP MINI System: Windows XP SP3 Proiblem: There is a webcam installed on this computer. I am not able to access it. I don't use if often, I have not used it in a while, but I recall that I...
XP is a dead OS for 3 years, getting help is not easy, due to that.
why not reload, the OS, fresh (F11 key), i bet its infected with viruses., as most XP system all are.
the HP manuals tell you how to use that, my guess lost.
what are you wanting to do with said cameara"
use skype or just do selfie, or just what?
the usage factors dictate what software one uses.
the hp pages are below.
see those books there, called guides?
here is the offical hp page (for guides)
https://support.hp.com/us-en/product/hp-mini-110-1000-pc-series/3943764/manuals
mini users guide, XP, read that? bet not.
read page 7, of the first guide it says
NOTE:
To capture videos, you need to install additional
webcam software.
page 42 states
Webcam
Your device includes an integrated webcam, located
at the top of the display. The webcam is an input
device that allows you to capture still photographs and videos.
NOTE:
To record videos, you need to install additional webcam software.
To access the webcam:
1.
Click
Start
cam-zpkvzoipjoo2bs5rvhf3aq5v-5-0.jpg if the driver is bad,
look in device manager and see if the cam driver is missing
(unknown,red,yell marks)
or right click it and pick, update driver, (be internet connected)
May 03, 2017 | HP Mini 110-1037NR Netbook
How do I get into safe mode on HP mini 1000? XP OS
To get into safe mode on any computer running Windows you press F8 before or right after the Windows splash screen comes up. You will have three options for safe mode:
Safe Mode: Only the absolutely necessary drivers load.
Safe Mode with Networking: Same as above plus the ability to use the internet/network access
Safe Mode with Command Prompt: Boots into safe mode with a Command Prompt for command line work.
Hope this helps.
Jesse
Jan 08, 2010 | HP Computers & Internet
HP Pavilion DV1000 drivers...
I found the problem to be a rather simple but frustrating one....when is an HP dv1000 not a dv1000....almost always!! You cannot get the correct downloads based on the model number on the tag. You must specify the PRODUCT NUMBER on the HP download site from the tag, not model. You can enter the general DV1000 and get to the download page and look for the entry "Not your Product?!" Follow that link and enter the PN from the tag....download those and you will get drivers that work with your unit. My "DV1000" was actually a DV1660!!!!
Jul 26, 2008 | HP Pavilion dv1000 Notebook
Wireless internet problem
Hi
I think your Operating System (OS) software installed after formatting does not have drivers for the wireless network card.
You did not provide any clues about the OS and the Network (Model/Brand) installed.
Dell Inspiron 6000 did ship with Windows XP as the Default OS and Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card or Intel PRO Wireless 2200BG, 2915ABG Wireless LAN Mini Cards as options
First, check the Original System Configuration to find out the built specification of the Inspiron 6000.
Enter you system tag. Click on the Original System Configuration Tab. Check the factory built specification and note the Wireless Card installed from the factory. If you have not changed or upgraded the Wireless Card, download and install the drivers from the list below.
Dell Wireless 1350, 1370, 1450,1390, 1490, and 1500 series Mini Card Drivers
Intel PRO/Wireless 2200BG / 2915ABG Wireless LAN Mini Card Drivers
I am almost sure you will need drivers for the Chipset, onboard network and video.
Intel Mobile Chipset
Broadcom 440x 10/100 Integrated Controller Driver v.4.25
Video (as above check the factory spec if you ordered the ATI MobilityRadeon X300)
Intel Graphics Video (onboard) Driver v.6.14.10.4609
ATI MobilityRadeon X300 Driver v.8.162-050803a2-025823C
Let me know how you get on.
Mike
May 29, 2008 | Dell Inspiron 6000 Notebook
Wireless device
Visit hp.com and download the Vista driver for your network adapter.
Dec 28, 2007 | Broadcom BCM94306MP - IEEE 802.11b/g...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
