Question about GE WBVH6240F Front Load Washer
My question is; the washer,model,wbvh6240 has any filter
  • 33 Answers
No , all new front loads have a self cleaning filter. Therefore nothing needs to be emptied or clean. The little trap door in front of the washer is to drain it in case of a power failure when the washer is full of water. .
Posted on Mar 15, 2011
  • barelegsbabe
    barelegsbabe Apr 14, 2012
    OMG Dork! Obviously you have never cleaned the trap out! NECESSARY to protect your water pump!!! Don't clean it you will be replacing the water pump after something eventually gets through.
    I have found quarters, bobby pins, drum Keys, a little screwdriver, bottle cap and a darn spoon!!!!!
    I don't empty mine often because mine is the first models where you have to take the bottom front panel off to get to the trap. When I do clean it I have to deal with water all over the floor. Does not mater what I have tried the pump lines hold a bucket of water :(
Testing the control panel for damage on a front load washer
How to Diagnose Washing Machine Control and Program ...
? 9:08
https://www.youtube.com/watch?v=QYPqpjLV7s4
Nov 11, 2013 - Uploaded by eSpares
I have a bosch front loading washer that's doesn't have code board. .... there's a clicking behind the front ...
[PDF]GE Front Load Washer - Atech Appliance Repair Service ...
www.atechappliancetechnician.com/GE_Washer_FL_WBVH6240__WC...
Louisville, Kentucky 40225. 31-9135. GE Front Load. Washer. WBVH6240. WCVH6260 ... damage. The man u fac tur er or seller cannot be responsible for the ..... Service Test Mode . .... accessible on the control panel's 7-segment display.
Jan 05, 2016 | Washing Machines
GE WASHER MODEL WBVH6240 DRUM NOISE
No it's supported by bearings I believe you have bearing issues look your model up on partselect dot com and take a look at assembly
Aug 03, 2017 | Washing Machines
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
GE front loading washer WBVH6240 leaks during fill cycle..solutions??
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
Nov 27, 2009 | Washing Machines
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Won't Rinse
Had this same problem with my GE WBVH6240 Front Load Washer which we have had for about 5 years. After performing surgery on it; cleaning out the drain hoses, cleaning out the filter several times, checking the operation of the pump, checking the water pressure coming in to the washer, finally narrowed it down to the water valve. Ordered a new valve through Appliance Parts Pros. Got it in 2 days through regular shipping, installed it in less than 10 min, ran it through a quick wash cycle and everything works 4.0. Don't know which parts you replaced but this fix which I eventually got to only cost $50. Saved me hundreds and/or the possibility of buying a brand new washer. Hope this helps.
Dec 05, 2008 | Whirlpool GHW9100L Front Load Washer
Washer
I have notice this problem with a lot of front loaders. I would check the manufacture warranty to see with is covered and if you bought an extended warranty, use it, keep your receipts for your previous purchases.
Dec 11, 2017 | GE WBVH6240F Front Load Washer
GE WBVH6240
Disconnect power to machine,
Drain all the water you can.
Remove the bottom access panel ( 3 screws on bottom plate)
open the large plastic filter in center
have a tray and towels to catch the water,
remove all clogging material,
look in with a light and turn the pump , it should turn freely.
Jan 27, 2008 | GE WSXH208A Front Load Washer
GE WBVH6240F Front Load Washer Logo
134 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
