How do i get rid of bear shear - Computers & Internet
    President:
  • 1,623 Answers
Go into add/ remove programs(XP) or programs and features(VISTA / WIN 7) and click on it and uninstall it
Posted on Mar 15, 2011
While mowing the drive belt tightner spring broke. I bought a replacement but the blades will not engage. The drive belt has been routed properly. it seems as though the blade's drive shaft will not spin.
Check and see if the shear pin has broken. If the pulleys spin but not the blades then the shear pin in the pulley or shaft has broken.
Mar 30, 2015 | Garden
Why does the "shear pin" on the wheel axle keep shearing off?
Its suppost to do this to keep from damageing the transmission and gear reduction case on the unit
You must be hitting things while snowblowing that go beyond limit of the brakeing point of the pin .
Chunks of ice will case problems with smalled low powered mechines bigger ones to but it jambs them but the parts are bigger so the pins can be stronger .
Keep the same pins that are ment for mechine and use it carefully
Mar 23, 2015 | Garden
We have an Ignis awf 595 washer dryer. The machine is now beyond economical repair due to the drum shearing off its bearings. What would cause this to happen.
It would be caused by a corroded and then seized up drum bearing from a water seal leak, detergent is very corrosive and very quickly ruins the drum bearings.
Feb 06, 2012 | Maytag Washing Machines
Hi Gene, I have an Electrolux FEX831C30 stacked washer and dryer. the drum in the dryer has completely come loose and has dropped to the bottom of the dryer cabinet. there were two screws in the drum. what...
Good Morning Brian,
The reason the drum has fallen free from the rear is a defective rear drum bearing and that drum bearing that has sheared itself off of the bearing support.to repair that dryer ya would need to replace the bearing kit its part number 5303281153 and would be in stock at your local applince parts store or online at searspartsdirect.com, repairclinic.com, apdepot.com, partselect.com, or apwagner.com
Before replacing the drum the drum bearing you should also inspect the heat element since when the bearing shears off its not that uncommon for the drum to fall onto the heater shroud and also break the heat element
While this Youtube video i have included the link to shows how to replace the drum bearing in a full siz e free standing (not stacked laundry center) dryer the process of how to replace the rear drum beaqring is exactly the same and that video should help ya http://www.youtube.com/user/RepairClinic?v=67hOqSFnX8g&feature=pyv&ad=9033434261&kw=drum%20bearing
Good luck,i hope ya find it very simple to replace that bearing,
GENE
Jan 31, 2012 | Washing Machines
My italjet f50 sheared a bearing in the gearbox i stripped and replaced the bearing but when i removed the side casing there was no oil in it cant find where the oil goes thanks
The left side casing should not have oil in it. The bearing gets lubricated by the fuel/oil mixture in the crankcase. Please rate my answer.
Apr 26, 2011 | Italjet Grifon 900 Motorcycles
Ive got a yamahaTTR600 2003 (9000km) thats sheared a balance shaft woodruff key causing the crank rod to colide with the balance weight. Im told its a common fault with this model. When I rebuild the motor...
I would not get rid of a balance shaft you will have premature bearing failure. I would machine a spacer or caterpilller makes a great compound just for that, cant think of the name of it right now but a cat dealer can help you find that compound
Apr 05, 2011 | 2003 Yamaha TT 600 R
Motor works but doesnt turn spindle with blade on it
you may have (probably) put something in there that wouldn't chop or grind, and the blade wasn't able to turn. When this occurs, a safety feature called a 'shear pin' breaks. The shear pin passes through on side of the base of the blade, through the motor shaft, and out the other side of the base of the blade. The pieces of the shear pin have to be removed, and replaced with a new pin. A common roll pin of the appropriate diameter should do the trick. Bear in mind the shear pin is a 'pressed fit', so removal of the old bits may be difficult. But it can be done.
Feb 06, 2010 | Microwave Ovens
Rear bearing on drum has snapped is it repairable
The bearing shaft is bolted on the bulkhead depending on the make and model. Provide these and I can be more specific.... Eric
Jun 17, 2009 | Dryers
Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Jun 04, 2009 | Hobart N50 Stand Mixer
Hobart d300
http://www.food-equipment.com/parts_Hobart_mixers.htm About halfway down. Hope this helps :)
Aug 01, 2007 | Hobart D300 Stand Mixer
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
