Question about Mitsubishi Televison & Video
My mitsubishi projector tv turns on but no picture and a screech coming from inside
  • 1,591 Answers
The screeching usually indicates a resonating transformer.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 15, 2011
I replaced a mitsubishi tv 62530 lamp. When I turn the tv on now the picture does not come on and then the tv turns off. What can I do?
Hello, it sounds like the lamp has gone bad. Unplug the tv and check the lamp and see if it's broken inside. here's a link on how to do that.... www.youtube.com/watch?v=90dfZGQoY8Q
Jan 03, 2015 | Mitsubishi Televison & Video
How do you connect your projector to your TV. It's a mitsubishi projector
Usually through a Video output on the tv, best connection would be from a set top box, DVD player or satellite/cable box to the projector. That way you'll get the best picture available
Oct 07, 2014 | Office Equipment & Supplies
When I turn on my WS65611 rear projector TV the picture comes on perfect but after a minute it starts going static then the picture will come back on then it goes stactic. This continues for as long as the...
A few things you could and should try, try something on a different input if you are using the coax connection just to know if problem exists that way, could be a bad tuner but that can be got around, also if on all inputs the set does have a hard reset that requires the Mitsubishi remote and a four digit code to enter the hidden option menu.
check the other inputs first please and let me know.
Aug 27, 2012 | Mitsubishi WS-65611 65" Rear Projection...
Tv turns on but no picture or sound
If its a Mitsubishi and doing this some of the lights on the front should be on or blinking?
Apr 26, 2012 | Mitsubishi For Projector Lamp Wd-60638ca...
How do you do a convergence on the wd73286?
Mitsubishi WD-73286 is DLP tv that does not have any convergence circuit inside.
Convergence is required in old model rear projection tv that has three basic colors picture tubes to generate color picture that projected on front screen of tv.
DLP tv has light engine to generate picture, it is similar to multimedia projector that throws its picture on wall.
Hope this info will help.
Thanks.
Mar 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi LCD Projector
power overdraw or overheating. theres a fan inside usualy that stops working.
Oct 09, 2008 | Dell 2300MP Multimedia Projector
Projector TV Image Discoloration
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
Feb 12, 2008 | Televison & Video
Mitsubishi 65831
sounds like the projector globe is gone. i think you will need to replace it. if you are lucky there should be a pannel on the side or rear of the tv that allows you to replace the globe. pricey though.
good luck
smeags
Dec 31, 2007 | Mitsubishi Diamond WD-65831 65" Projection...
Replacement lamp
have the tv looked at by a professional that knows what he's doing.
Jul 25, 2007 | Sanyo PLV-Z4 Multimedia Projectors
Televison & Video Logo
150 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
