Question about Carrier LFP Humidifier
Carrier # HUMCCLBP2018-A humidifier has a spring loaded steel shaft that plugs the hole in the rubber gasket that seals when compressed and allows water to flow. When the solenoid magnet activates it counters the spring and opens the path for water to flow. The spring corroded and broke. I need the spring and if possible an exploded view drawing of it's assembly. The solenoid electrical part works fine. Where can I get the spring or it's specification? and / or the parts drawing.
    Brigadier General:
  • 4,736 Answers
Here's a link to your Owners Manual, in case you've misplaced yours. Hopefully it will help you. .http://www.appliancefactoryparts.com/content/pdfs/109397.pdf
Posted on Mar 15, 2011
Idylis #0484756 unit shuts off tank emply but take is full
Just purchased a Idylis model 0484756 and it has no
operators manuel. Is there one available?
Where?
Thanks
Jan 20, 2014 | Humidifiers
No water going over pad
Check to see if you have water on the inlet side of the solenoid valve by loosining the compression fitting, if water is there then the solenoid valve is not working, if no water at compression fitting then the saddle valve is either plugged up or faulty
Nov 19, 2012 | Carrier LFP Humidifier
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
Why won't the water stop running?
When my humidifier refuses to turn off, it is always because the plunger in the electronic valve is stuck.
When the rheostat senses low humidity, it sends current to a coil, this creates a magnetic field that pulls a plunger up into a tube away from a rubber gasket (hole in center to match plunger) and water flows thru the hole. When humidity is high, the rheostat stops the current, and a spring/gravity push the plunger back against the gasket.
The plunger or the tube can get deposits, or just rust ever so slightly, and then the plunger gets stuck in the up = on position.
Buy a new solenoid valve $$$, or take your solenoid apart and clean the plunger and the tube with steel wool.
Jan 09, 2010 | Aprilaire 600 Humidifier
Water is not leaving the tank o enter the heating chamber. The gasket/spring lock appears to be stuck or inserted incorrectly
I am having the same problem. The gasket seals completely around the little post and no matter how I insert the post, no water comes through.
Please let me know if you learn of a solution.
frawlsters@aol.com
Thank you.
Jan 09, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Humidifier not working
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
May 18, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Pollenex HealthAire UltraSonic Humidifier SH50 need new washer
Sure. But if your homemade gasket leaks try a little 100% silicone caulking. It smells bad for an hour or so but it will help. If you use the silicon make sure you allow it to thoroughly dry before you get it wet or it "will" leak.
Good luck
HVAC Teacher
Feb 18, 2009 | Aprilaire 700 Humidifier
Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Nov 28, 2008 | Vicks V3100 1.2 Gallon Humidifier
Slant fin gf-210 needed part
slant fin sold the humidifier biz to another company.  info at the slant/fin site http://www.slantfin.com/contact.php
Nov 18, 2008 | Slant Fin GF-210W 2 Gallon Humidifier
Carrier LFP Humidifier Logo
401 people viewed this question
Top Carrier Humidifiers Experts
Paul Carew
Mack Baxter
Tom Chichester
Are you a Carrier Humidifier Expert? Answer questions, earn points and help others
