Question about Viper 7153V 1-Way SuperCode Remote
I loss my manual for my Viper remote starter model #7152V. My automatic starter will not start my car, nor lock the car. I replaced the battery and still nothing. I am not sure if I have to re-program the remote starter, if so where can I get the instruction online. Can you please assist
  • 22 Answers
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
Posted on Dec 04, 2008
  • 53 Answers
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Posted on Jul 12, 2009
  • 24 Answers
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Posted on Nov 04, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
Viper Remote starter (Model 4115V1) does not immediately turn on...car will try to turn-over does not and about 45 seconds later, engines turns over. Viper was installed at Best Buy (authorized dealer
It sounds like a problem in the remote start module that was installed. I assume it has not always done this. See what type of warrenty you have on it. Probably none but sometimes suprises happen.
Nov 28, 2014 | Remote Start System
Viper 5101 no longer starts
are your brake lights functioning properly? remote starts sometimes use this as a fail safe, or a bent hood pin switch? Also It may need the tach reprogrammed if used. there may be a seperate fuse for the starter.
here is the link to the installation manual: http://www.directeddealers.com/manuals/ig/viper/n4102v_2008_09_web.pdf
and the page regarding this issue: • The remote start will activate, but the starter never engages.
1. Check for voltage on the purple starter wire two seconds after the remote
start becomes active. If there is voltage present, skip to Step 4. If there is
not voltage present, advance to Step 2.
2. Check the 30A fuses.
3. If the gray/black wait-to-start wire is detecting ground upon activation, the
starter will not crank.
4. Make sure the purple starter wire is connected on the starter side of the
optional starter kill/anti-grind relay.
5. Does the vehicle have an immobilizer? Some immobilizer systems will not
allow the vehicle to crank if active.
6. Check connections. The heavy gauge remote start input wires on the
heavy gauge 10-pin connector should have a solid connection. "T-taps"
or "scotch locks" are not recommended for any high current heavy gauge
wiring.
good luck.
Apr 17, 2014 | Remote Start System
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
May 12, 2011 | Remote Start System
I have one control only the (p/n 7152v) how can I reset it. My car is lock and my control is not working..
You might have to re-learn the remote to the system. Assuming you've already made sure the battery in the remote is not dead (if you still have lights on the left side of the remote when you press a button, then the battery should be fine and your car just isn't getting a signal from the remote).
Step 1. If the battery is good, here's how you reprogram the remote. First, open the driver's door, the day must stay opened during the programming process.
Step 2. Turn the key to the on position.
Step 3. Within 10 seconds press the valet button once and release it, then press 1 more time and hold it. (the valet button located on the antenna/LED "control center" most likely attached to the top edge of your windshield by the rearview mirror.
Step 4. Press the lock button once on the remote. You should hear a confirmation chirp from the siren letting you know it has learned the remote. At this point you can release the valet button.
Step 5. Remove your key, close the door and test lock/unlock, start and stop functions.
You should be fine at this point, if the system is still not working there is another problem with the system that would need clarification to pinpoint.
Mar 29, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Jan 05, 2011 | Remote Start System
I bought a used dodge pickup equiped with a viper remote system,it worked fine until the last few days now Iam unable to start the vehicle with the key and keep it running.I took out the battery from...
On many of the Viper models, the symptom you are describing is because the remote battery is low. The remote can't be too far from the vehicle. If it is, the system see it as you forgot about the vehicle being remote started, and shuts it back down. A weak battery creates a weak signal and makes the unit 'think' you are far away. The Viper website has instructions on how to disable the whole system, there are many different versions, so find the box and get the model number from it, you will need that to get any further.
Jun 02, 2017 | Viper Televison & Video
Car won't stay running after using Viper 150ESP car starter
you may have hurt the alternator when jumping check that
Apr 07, 2009 | Remote Start System
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
Viper 7153V 1-Way SuperCode Remote Logo
302 people viewed this question
Top Viper GPS Experts
Are you a Viper GPS Expert? Answer questions, earn points and help others
