Question about Hitachi 65F59 65" HDTV
I tried to clean the screen with a solution that works on any screen and it turn brown in the area. Tried warm water and did nothing. I noticed their is a crack in the screen. I want to remove the screen.
  • 147 Answers
For the crack, you can buy a new screen from www.TvRepairKits.com though it will cost a little over $100 because it will cost about $100 to ship. as for the drown, i don't know how to fix it. to remove the screens just pop off the part covering the edges of the screen
Posted on Mar 19, 2011
I have a tumble dryer Condensed Hotpoint Aquarius tcm570. The empty water indicator is on. I have cleared the,filters and no water was in tank. I have noticed it is taking longer to try clothes and the...
Dryer need to be clean out .
all area of lint screen down to were are comes out or fan may be blowing stripped blade on motor.
Need whole model # of dryer to quote you parts cost
Mar 01, 2015 | Hotpoint Dryers
Oven control valve wont shut off gas completely
This could be due to a build up of grease or tiny food particles behind the control tap handle;
1/ Gently prise off the handle ( it comes towards you )
2/ Wash handle in warm soapy/detergent water, till clean, then dry.
3/ Use a lint-free cloth or a sponge with warm soapy water to soak the tap control spindle and a plastic knife to clean off any stubborn bits.
4/ Wipe clean , replace handle part, try turning off.
Jaylo264
Jan 03, 2011 | Brown Stove Works TM210 Gas Kitchen Range
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
Few buttons wont work
My best guess is that you touched that area with wet hands and little water got inside and corroded the circuits. Regardless, the phone needs to be opened and cleaned on those buttons and on the contacts
Mar 26, 2009 | RIM BlackBerry Bold 9000 Smartphone
Brown residue from muratic acid fumes on stainless steel applianc
Just a thought it may not work.
Since Muratic acid caused the trouble try it to remove the stain. Then after its removed use baking soda to kill the acid and within 3 toi 4 hours re apply baking soda and re clean. Maybe do the cleaning 3 times just to be safe.
I only say this because to remove oil you use an oil based solvent. Water use a water base solvent.
So maybe ...
Then again maybe not
If this works or doesn't Id like to know.
The last thing to use is a piece of aluminum tape to cover the area so its not brown.
If this helped you please rate me accordingly and good luck.
Mar 13, 2009 | Kenmore Refrigerators
Humming from Water Solenoid area
It may have some dirt or sediment clogging it making it work harder than usual.
Jan 23, 2009 | Washing Machines
Htc touch screen not working.
Hi, I had the same problem. Whenever, I touched my screen the wrong things would respond, then finally one day my phone locked & when I tried to unlock it the screen wouldn't respond at all.Took my phone to 3 sprint stores and all the techs couldn't help. One even accused water damage or overheating because they saw spots under my screen. But I never wet my phone so I thought it might be overheating since I do live in a warm climate. They all tried to get me to buy a new phone, which seemed like a scam. I didn't want to hard reset & lose all my data so I looked closer at the screen & noticed the spots didn't look like water spots & peeled the screen back. I noticed that the glue from around the screen actually leaked onto the screen, so I dampened one end of a q-tip & wiped the glue off the dryed it with the other end. I turn the phone back on and the screen worked fine. Try cleaning thr screen before doing a hard reset or paying for a replacement phone. It'll save you time & headache.
Hope this helps =)
Jan 09, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Vicks caporiser is spitting water instead of steam
Clean the unti - and do not add salt. I live in a major hard water city...and was amazed at how much dirt the tank collected. I tried adding salt to to stop the spitting, which did make a lot more steam, but did NOT stop teh water spit. I also noticed, with salt added, water in tank would only last 4-6 hours, not the 18-24 hours it should. I just figured it out, and now mine works great again, and does not spit. I cleaned the water tank throughly, several rinses, then wiped out entire inside. If you want it to work like new, you have to keep your tank as clean as new. I am going to start filtering my water that I put in with a double pantyhose I made simply so there no more dirt ~ a clean tank will fix the problem, it did mine :)
Aug 03, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Indest Fridge Freezer
Possibly something was spilled and it got to the door gasket. Clean the door gasket area with warm soapy water. In the door there is nothing critical to the system operation that should cause the condition you have.
May 17, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
Jan 01, 2008 | Continental Manufacturing Company CE23201...
Hitachi 65F59 65" HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
