Question about Philips Magnavox 51MP392H Rear Projection Television
We have a 1998 60 inch Phillips Magnavox. The screen has a yellow cast. Anything white has a green hue. We took the back off and wiped off the lamps. What do we need to do?
  • Philips Master
  • 8,617 Answers
Replace the CRT coolant. You can get the Phillips CRT coolant kit from www.tvrepairworld.com the kit contains the coolant and the CD with instructions.
Posted on Mar 18, 2011
Phillips Magnavox 9P6040 C104 tv color adjustment help
If you turn color off and stand back and examine the screen---if it is not black and white but yellow looking you have bad Glycol in the blue picture tube which is quite common.
Easy way to know for sure is with set on and rear cover removed peek with a small mirror at the three lens---don't touch anything with the set on===each tube red,blue, green should have a picture with the set on.
Likely you will find the blue one looks like a floodlight with little or NO image/picture.
May 18, 2012 | Hitachi Televison & Video
What causes the yellowish hue in the centre of the screen
There are several different types of projection sets: some use 3 picture tubes, red,green,blue--if this kind of set is what you have the coolant used in the blue tube is bad-----this type of problem leaves red and green which = yellow.
Most common in Samsung, Philips, Magnavox type sets.
If it is a newer set without picture tubes (a dlp style set) yellow in the middle of the screen would denote a damaged optical light engine.
Let me know brand, model number, date made----all are on back of set.
SD TECH
Feb 25, 2011 | Televison & Video
What kind of lamps ???
You have 3 tubes red-green-blue.
Encompass Parts might have some in stock 1-800-638-3328
Mar 23, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magnavox mptv68a
Last year i had a phillips 100hz tv which had a similar problem.
There can be one of 2 major problems :A processor chip which controls the colour and the tube which could have failed or both.
This could be an expensive repair if the spares are available,(Usually imported from there singapore branch)
I would first check the warranty and then take it to the agents.
Apr 28, 2008 | Philips Magnavox 27MS343S 27" TV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
HDTV tube television - with green tint on right half of screen
i had the same prob on my 28 inch hd sanyo crt , i took it apart and reconnected a few plugs and havent had any trouble yet { be sure to unplug it and b quite careful even then} saved me a couple hundred $ !!!
Nov 19, 2007 | Televison & Video
Blue out of focus; casting blue "glow"
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Jun 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Yellowing screen off-center - not a convergence issue
You might want to try the optic lens adjustment screw on the side of each crt. Mark them before moving.
May 30, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
